Ravelco Best Security You Can Buy!!!!!!!
I had one of these, I took it out. I am pretty sure I ended up throwing it away. If you hid the port for the special key it would confuse a thief for ever.
I didn't like to use it because I found it annoying. Its a good system, it hooks into your ignition wire. There is a special one of a kind key that you have to plug in that will complete the ignition circuit. The car will not start with out it. If you hid where the key goes, a thief will not be driving your car away. Only way then is a tow truck.
dont really need a professional.....not too hard just time consuming because with the space you have its a little tight but if you know how to take out a harness it will take about maybe a little over an hour to do
