Another ef problem (no power in fusebox)
Old Feb 15, 2010 | 02:04 PM
nycpatron's Avatar
Default Another ef problem (no power in fusebox)
ok i have a 88 dx has b16a in it obd0 it has a 88-89 si cluster and 90-91 dash im not sure if the engine harness is the the original one and dont know how to tell the diff
the problem is that my cluster dont work at all nothing lights up speedo,rpm and lightings dont work my tail lights none turn on I tried checking the fuses all of them are good but most dont have power....other fuses like alt and starter fuse have power but not the rest hazards dont work either or turn signals i fixed most of the wiring on the car putting them back to original positions the car has been hacked pretty bad also the wipers dont work
they used to work before i put everything where its supposed to be like before lets say honda had a blue/white wire they cut it and connected it to something else so all i did was just put the wires correctly and now it dont work.
thanks for y0our time
Old Feb 15, 2010 | 04:23 PM
black0hatch's Avatar
Default Re: Another ef problem (no power in fusebox)
sounds like its most likely a wireing problem since its all hacked. but you could check grounds theres alot of them.
Old Feb 16, 2010 | 12:30 PM
nycpatron's Avatar
I been thinking about it all night and idk if it might have to do with the 2 lil boxes that go right next to the head lights for some reason they where removed i forgot to mention that other than that the only other thing i see is the deleted the main relay and used a regular relay the car turns on and drives fine its just turn signals tail lights thats not working im going to check it all out again
BadassEFdriver
Nov 1, 2010 07:56 AM
JDMDALOUIE
Mar 1, 2010 11:06 PM
kaoticimports
May 31, 2004 08:53 PM
Danethomp
May 18, 2004 05:45 PM
