Wire Up 02 Sensor
Old Feb 15, 2010 | 09:04 AM
voz's Avatar
voz
Default Wire Up 02 Sensor
97 Civic with a JDM D15B using a P2P ECU..
Only throwing one code -
PO141
02 Sensor Heater
Circuit Malfunction
Bank 1 Sensor 2
NO REAR 02 SENSOR PLUG..
I found the 02 sensor behind the dash and a few cut wires,,
I need to know which wires go where..
unwrapped the plugs going into ECU and this is what I found, no idea what these connections were trying to accomplish..
They were spliced into those brown wires which went straight to the 02 sensor.. but was cut from sensor and taped
These 3 plgs were just sitting behind the console. The middle plug is taped with some silver stuff and it feels like they are jumpers into plug. Car is a A/T converted M/T. i was thinking it was something for the A/T Shifter.
Old Feb 16, 2010 | 10:26 AM
voz's Avatar
voz
Default Re: Wire Up 02 Sensor
73 views and no replies...
I have read this--> https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-wiring-secondary-o2-sensor-directly-ecu-2509133/ and it did not have a concrete answer..
Thank You!
Old Feb 17, 2010 | 05:01 PM
Relic1's Avatar
center plug - auto shifter plug - ignore
ECU wires - those blue things cause more problems than a fat guy on a little bike.
Plug A
blue - not sure what this is. do you know which point it runs to?
A5 - black/white - Secondary O2 heater control
Plug D
D11 - green/black - sensor ground (should be run to red/yel (D13) - sensor ground - a slightly different reference point which may make a difference it may not)
D14 - white/red - Secondary O2 signal
to wire one up use this to identify where each wire is located.
http://www.b18c5eg.com/obd2a.jpg
O2 heater (typically two black wires, can be two white wires, does not matter which it which)
black/yellow - ignition 12V - located at the main relay or under the hood in many places.
A5 - black/white - heater control
O2 signal (typically two different wire colors, can be green & black or white & green depending on which O2 you have)
D14 - white/red - O2 signal
D13 - red/yellow - O2 ground
Old Feb 18, 2010 | 04:34 AM
voz's Avatar
voz
Gracias,
I will be soldering and heat shrinking all connections this evening..
guessohw
Nov 11, 2011 02:50 PM
Terabass
Jan 24, 2007 07:27 PM
743power
Audio / Security / Video
Jan 23, 2006 06:11 PM
GRAVEDIGGER
Oct 8, 2002 02:11 PM
