92 Accord vibration
Whats up,
I Have a 92 Accord EX 5-speed with a slight vibration. It is worse under a load(like accelerating on the freeway) but still noticeable in neutral. Only there if the car is moving. Axles or motor mounts? It is not a horrible vibration, but enough to feel through the floor board and feel in the steering wheel. Almost kinda like slightly warped brake rotors...but obviously while not using the brakes.
Trippy thing is it has seemed to get worse after having the front brakes done which makes me thing it could be axle related?
Car is 100% stock.
Thanks in advance
Car is 100% stock.
Thanks in advance
bald spots in tires? has the car been sitting for a long period of time? wheels may be unbalanced.. theres so much that could be wrong.. i got an accelerating problem with my 95 accord also.. so im still doin my homework on whats wrong also
Ok cool...ill look into the intermediate shaft. And just another thing it is not related to engine RPM in neutral at least, just under a load.
Tires are fresh, air pressure is good. Had them rebalanced to check and they are all good. It feels drivetrain related for sure to me since putting a load on it will make it worse. Im pretty new to the transaxle style set-up so I appreciate the replys.
Thanks again
Thanks again
1990, 90, 92, 93, accelerate, accellerate, accord, engine, ep3, suspension, type, vibrate, vibration, whats, wrong
