need help
Old Feb 14, 2010 | 08:36 PM
TeamPrestige's Avatar
Default need help
i own a 1990 civic sedan DX and my speedometer and odometer doesnt work. My temp and gas gauge work though. any solution to my problem? thanks
-yoshi-
Old Feb 14, 2010 | 08:52 PM
D16SiHatch's Avatar
Default Re: need help
it's possible there is an issue with your gauge cluster, but more commonly on these cars the cables pop out or break in 2 pieces within the cable shroud. the speedo cable comes out of the driverside firewall and goes to the vss at the rear of the trans. check it over and see if its seated in the tranny good. if it is then pull the cable out of the speed sensor and spin it manually. you should see the cable spinning behind the dash once you remove the gauge cluster. if you don't see it spinning then the cable has snapped internally.
Old Feb 14, 2010 | 10:16 PM
nice thanks for the heads up
i'll try this and let u know how its goin
GPC91
11
Sep 12, 2012 07:33 AM
Barry116
Feb 8, 2012 07:41 AM
G. Man
Classic Hondas
Jul 8, 2011 07:34 AM
blumpfish
Jul 25, 2006 04:52 PM
shai x boi racer
Jul 14, 2005 04:52 PM
