Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2004 Honda Accord Headlights Dim While Driving??
Old Feb 14, 2010 | 04:31 PM
Project Cortez's Avatar
Default 2004 Honda Accord Headlights Dim While Driving??
I've got a 2004 Honda Accord Ex 6 banger. While driving with the headlights they will dim and then go to normal. I've had it at the dealer they've checked alternator and did a test on the battery. They advised getting a new battery. I bought a brand new one and the problem continues. I again had the alternator checked at a different shop and it checked out okay. The guy at the shop suggested maybe there is a grounded wire. I checked and could not find anything. Would the size of the battery have anything to do with it?(ie cold cranking amps) Anyone else having a similar problem? If so let me know what you did. Thanks
Old Feb 14, 2010 | 11:06 PM
Snakebyt's Avatar
New User
Default Re: 2004 Honda Accord Headlights Dim While Driving??
i have the same problem with my 2003 Accord
Old Feb 14, 2010 | 11:28 PM
90sedan's Avatar
It's very likely that its a faulty ELD. You'll need to replace the underhood fuse box as the ELD is non-serviceable and is contained within the fuse box.
Old Feb 16, 2010 | 04:08 AM
Thanks for the information, I'm just curious why the Honda dealer wouldn't pick up on that. 90Sedan did you have this problem with one of your cars? Is this an expensive part? I would hate to replace it and it not be the problem.
Old Feb 16, 2010 | 10:08 AM
90sedan's Avatar
I'm not sure why the dealer missed it either. But there is a TSb for it. I work for a dealer and have replaced a couple of them on customer cars.
I don't know the cost of the fuse box, but i would try an online honda parts dealer, it will be much cheaper than buying it in-person from a dealer.
Old Feb 17, 2010 | 07:18 PM
Thanks for the info 90Sedan
Old Nov 30, 2010 | 04:54 PM
If anyone else is having this problem the ELD can be replaced without replacing the whole fuse box.
http://www.elementownersclub.com/for...ad.php?t=51803
Old Dec 2, 2010 | 12:41 PM
I stand corrected, need the whole fuse box.
Old Dec 2, 2010 | 06:22 PM
90sedan's Avatar
That is correct, for Accords, the entire fusebox will need replacement. Elements can replace the ELD separately.
Old Dec 2, 2010 | 10:53 PM
Anushka's Avatar
http://y.ahoo.it/tUhGzo
Check free, your vehicle history.
Do not have to pay
Good luck
Aidan Franits
Honda Accord 2016- 2017
Jul 5, 2019 06:47 AM
tom albright
Feb 6, 2016 04:36 PM
crossmiles8
Apr 3, 2013 07:42 AM
PsykoMoulton
Oct 6, 2011 09:15 AM
timmer60
Dec 24, 2006 02:09 PM
