90si B16a3 help cranks wont start wont rev over 3k
Old Feb 14, 2010 | 03:45 PM
day1's Avatar
Default 90si B16a3 help cranks wont start wont rev over 3k
Bought a 1990 Civic Si shell. My crx was a rust bucket so I swapped my b16a3 that I had in it into my 90 Si shell. The shell did not come with a wiring harness so I used my harness from my CRX Si (1988 ZC) I have a conversion harness for the dizzy.
I also have the obd0 to obd1 conversion harness for my p28. The crx ran great. The car cranks but wont start I have the ZC injectors on the b16 fuel rail. I had to pin out the driver wiring clip on the LF strut. I had 2 wires left over blue and black with yellow. I was told it is for a fitv i believe for the d16 but the b16 doesnt run it. Colors dont match up perfect on the RF strut tower clips but it plugs in. (The 14 wire clip and the 6 wire clip)
Ok so for the problem... cranks but wont start I spary a little starter fluid and i can get it to kick on playing with the throttle a bit. After about 20secs of playing with the throttle the car will idle on its own at 700-800rpm. I go to rev it and cuts out immediately at 3000rpm. After i turn it off it will start back up if hot. I have swapped 3 main relays. If the motor is cold or sits for more than 20mins then it wont fire up.
Any help is greatly appreciated.
Old Feb 14, 2010 | 04:00 PM
littlegrayhonda's Avatar
Default Re: 90si B16a3 help cranks wont start wont rev over 3k
that harness you took off the crx, is it in the exact order you put on in the si, might have to do with some of that wiring bro.
Old Feb 14, 2010 | 04:11 PM
day1's Avatar
Wire for wire its correct and the injector resistor plugged in its just those 2 wires that are hanging for a sensor the b16 doesnt use... anyone have wiring diagrams for the crx
Old Feb 14, 2010 | 04:14 PM
black0hatch's Avatar
i would say wireing too. are you getting a cel? you probably allready know that 88 si engine harness is different from 89-91 si harness. you should just get a 89-91 si engine harness that way all the wire colors and plugs will match up.
Old Feb 14, 2010 | 04:38 PM
day1's Avatar
Ya I cant find one for under $170 in my area and I really need this thing running I have all night tonight to wire it up if I have to. I cant find the zc engine harness on the passenger side diagram any one help me out
day1
Feb 13, 2010 04:16 PM
crxracer2006
Sep 22, 2005 11:46 AM
oldskool4life
13
May 15, 2005 01:58 PM
C-REX 88
Aug 8, 2004 07:19 PM
EGHatchy
Jul 11, 2002 11:24 AM
