FS:Honda&Acura...Garage Sale!!!!Take a look
Old Feb 14, 2010 | 04:00 AM
SlaminSohCivic's Avatar
Default FS:Honda&Acura...Garage Sale!!!!Take a look
Im located In Smithfield PA..By Unionotown PA
IM Trying to sell alot of parts because im going on vacation soon so i put a big price drop on the parts an if you want a deal meet me asap.So give me a call or txt..i dont read my emails so....Thanks
If 100% interested Cal 724-984-6442..Ask for Zack..If want pics ill send you over email or txt msg...
Selling...
Brand new Act xtreme 6 puck unsprung clutch disc...0 miles...$100,00
B18a1 Cable Tranny...Needs diff..$130.00
D15b8 Bottom End..Runs...Smoke's..Needs Rings...$100.00
92 civic Gauge Cluster..No tach..Auto...$35.00
D15b7 Stock Intake...$20.00
B18a Valve Pan cover Clean....$40.00
D16z6 Valve Pan Cover...$25.00
p08 ecu for 92 JDM D15B..V-Tech...$90.00
Delsol Complete Black Dash..Cluster...Armrest....No cracks..or Scratchs..$80.00
D16 OBD0 Msd Distributor Cap(New)...$40.00
d16y7 Bare Intake Manifold...$20.00
Tons of mounts Misc..D Series..Bseris...$25.00each
D16z6 5 speed Starter....$30.00
B18b Power Steering Pump An Resavor Tank.Works Good..$30.00
$1994 integra LS Cruise Control Uint...$30.00
Eclipse 14b Turbo Tiny Bit of shaft Play..Needs Clamp to hold together..$95.00
92-00 Engine Bay Fuse Box...al fuse's...$25.00
91 civic hatchback Stock Corner Lights Mint....$20.00
89 Civic 4 door Corner Lights Mint...$15.00
90 integra ls Injector Resistor Box...$25.00
91 Civic New Rotors Only 1000 miles...No ridges...Both...$45.00
1994 Integra LS Auto OBD1 ECU...$90.00
1997 D16y7 Auto ECU OBD2...$70.00
D16 Sohc Long Axle Good boots.....$35.00
D16Z6 Altinator Needs a pulley...$25.00
D16Y7 OBD2 Altinator....$40.00
New B18B1 Auto Stater....$80.00
D16 Manuel Starter....$35.00
D16y8 Intake Manifold...$55.00
94 integra 2 door Black full rear interior...$40.00
OBD1 D16Z6 distributor....$50.00
1997 4 door (2) Front fenders good shape...$50.00 Both
1997 civic 4 door Head light..Needs wet sanded...$20.00
1997 civic 4 door 2 Front Seats...Tan..Mint...$40.00
1997 civic 4 door Rear Seat....Mint just 1 lil burn hole...$40.00
1997 civic 4 door...Complete Tan Dash...Mint as hell...Includes...Cluster...Glove Box...Cup holder..Air bag...everything.....$120.00
1997 civic 4 door...Trunk Lid...No dents or Rust...No tail lights...$40.00
1997 civic 4 door Mint Tail Lights...$40.00
92 civic Gauge Cluster With Tach...$33.00
1997 civic 4 door Rear Bumper..good shape...$35.00
1997 civic 4 door....Driver Side Door..Good Shape...Includes..Mirror...Mint Tan Door pannal.....$55.00
Blitz AluminaDrive Boost Gauge Reads Bar....$55.00
B18B Stock Cam Gears...$20.00
92-95 Civic Driver Side Mirrior..Needs Sanded...$20.00
88-00 Under Dash Fuse Box...All Fuse's....$32.00
94 Integra Ls HubCaps....Black....Good Shape....$30.00
97 Civic 4 Door...Both Side Skirts...White...Good Shape...$45.00 Both
D16Y7 OBD2 Altinator...Good Shape....$35.00
92-00 Civic Hydro Slave Cylinder...$25.00
B18B1 OBD1 Auto Engine Harness....$65.00
D16z6 Stock Spark Plug Wires....$10.00
D15b2 Stock Spark Plug Wires....$10.00
Stock B18B1 Spark Plug Wires...$15.00
OBD1 D16Z6 Distributor...New rotor Button...$55.00
D16z6 Driver Side Engine Mount...Perfect...$30.00
D16z6 Timing Belt tensor....$12.00
94 Integra (NEW) Full Radiator...With Cooling Fan....$50.00
D16y7 Driver Side Engine Pillow Mount....$30.00
97-00 Obd2 Under Dash Fuse Boxs...All Fuse's....$30.00 Each
D16y7 Pillow Engine Mount Bracket...$23.00
94 Integra Coupe Passenger Side Door...All Power...No Door Panal...$90.00
94 Integra Coupe Sunroof Complete...Everything...Even SunRoof Switch....$75.00
94 Integra Coupe Complete Rear Wiper Setup....$40.00
94 Gsr Coupe Carbon Fiber Fakes Tail Lights...$40.00
94 Integra Couple Rear Bumper...3 lil Screw Holes...$40.00
94 Integra Auto Cluster...Has Tach....$45.00
94 Integra Steering Stem...Complete...Steering Wheel...Ingition/w key...Airbag....$85.00
94 Integra Windshield Washer Fluid Container Complete...$30.00
94 Integra B18b1 Half Shaft...$55.00
94 Integra Rear View Mirrior...$20.00
94 Integra Front Lower Control Arms...Bushings Are Good.....$50.00 Both
94 Integra Gsr Shifter Part of Linkage The Solid Part...With Curved Shfter...$35.00
94 Integra Coupe 3rd Brake Light Set Up Complete...$35.00
B18b Log Style Turbo Manifold...External Waste gate Flange...AN t3/t4 Flange....$45.00
D15B2 Stock Air Intake...$15.00
D15 Side tranny mount...$25.00
91 Civic SI Rear Seats..Rare Set...Minttt...$130.00
94 Integra Stainless Steel Axle Back...$45.00
88 CRX Si Rear Taillights..Complete...$50.00
94 Integra Bumper Marker Lights...One is cracked a lil...$20.00.Both
94 Integra LS Complete Rear Disc Swap...BIG upgrade for civic's..Include's...Full trailing arm..Cailpers...rotors..Struts&Springs.Both E-Brake Cables...Lower Control Arms...Brake Line..$235.00..If you Get it ASAP ill drop price
91 Civic Hatch Driver Side Door..Good SHape...$70.00
94 Integra Stock Tape Player/w Code...$20.00
97 civic Stock Radio...$20.00
91 Civic Front Aftermarket Sturts?...$65.00 Both
91 CRX Si Dash..Jet Black...Complete...$140.00
94 integra LS Stock Air intake...$30.00
Audiobahn 10" Speaker Box...No sub..Has pexiglass...Mirror...$40.00
Us acustics 500 watt amp...$40.00
Pioneer primer 6 Disc Cd Changer...$35.00
Ive Got Tons of other Honda &Acura Parts Not listed Give me a Txt or call with what you need an i 75% got it...Names Zack
Willing to travel..Give me a call....Looking For...91 civic hatch Fenders...Hood.....B series Engine Parts or Turbo Parts....
Old Feb 21, 2010 | 08:37 AM
accord91guy's Avatar
Default Re: FS:Honda&Acura...Garage Sale!!!!Take a look
have a set of d15 pistons and rods? lmk
SlaminSohCivic
Jan 10, 2010 02:59 PM
SlaminSohCivic
Dec 9, 2009 10:20 PM
SlaminSohCivic
Sep 18, 2009 10:18 PM
95hybridcivic
Jun 25, 2002 07:17 PM
