Clutch problems, cold weather?
Old Feb 13, 2010 | 07:17 PM
NL826's Avatar
Default Clutch problems, cold weather?
Can cold weather cause problems with the clutch? Can't get the car to go anywhere...
Old Feb 13, 2010 | 07:22 PM
mwaedow's Avatar
Default Re: Clutch problems, cold weather?
If it's worn out, then it might not have enough friction to catch the flywheel. If it's cold, then It could be even less tacky than it would be warm. Check your slave cylinder, make sure it's not leaky or worn out.
Old Feb 13, 2010 | 07:27 PM
NL826's Avatar
We don't have a slave cylinder, it's a cable clutch, but we'll check the flywheel in the morning I guess. Worked fine earlier, lol.
Old Feb 13, 2010 | 07:31 PM
mwaedow's Avatar
If it's cable, then maybe it snapped due to being cold. I've never worked on a cable clutch, so I dunno. Before you go pulling the trans, I'd definitely check the cable, though. I know that cables that open the hood latch and gas flap are known to snap or seize in cold weather. I have to put a new hood release cable on my car every couple years. They suck.
Old Feb 13, 2010 | 07:35 PM
grog's Avatar
Make sure your cable is adjusted properly, tighten it until the slack is taken up then back it off just a bit, too tight can cause premature wear of the clutch release bearing.
If the weather really is causing the clutch to slip then it must be on its way out.
kid_02131
12
Nov 6, 2013 05:32 AM
90civic1.5
Feb 17, 2010 09:29 PM
SeraphimKidd
Sep 14, 2009 07:53 AM
InJ3cted
May 24, 2005 02:16 PM
ninjaturtle1023
Jul 10, 2004 03:29 AM
