Parting out FULLY BUILT B Series, ITR Block, ITR Everything! Hondata, Hytech, Skunk2
Serious Buyer? Text/Call 913 636 7937
Parting out my motor
EDIT: More Parts Will Be Added
PM ME if you want to purchase anything!
I had ERL performance build this block for me for $3500.
Only had it for about 3000 miles.
I made 195whp and 149wtq at Supertune Performance with my S2S2 cams.
BLOCK SOLD
B18C Block
Balanced and Blueprinted
84mm Darton Sleeved
Carillo K1 Rods
JE 11:1 Pistons
ACL Bearings
ARP Mainbolts
LS Crank
A BNIB 84mm Cometic HG will be included with the sale.
TRANNY SOLD
00 ITR
Exedy Stage 2 Clutch
Exedy Flywheel
Clutch/Flywheel were both just installed when the block was installed.
TW: $2800 for the BUILT block and Tranny
I would rather not part these two, but 1800 for the built block and 1100 for the tranny.
SOLD $600 Spare ITR block, it does have OS pistons and will NEED a ring job. VIN is still intact
Precision 440 injectors $200 SOLD
ITR IM/TB : Hondata IMG included $150 SOLD
P06 ECU with Hondata S300 $550 SOLD
P06 ECU with Hondata S200 w/ Boomslang harness $150 SOLD
00 ITR P73 ECU $100 SOLD
Hytech Anti-Reversion Header $700 SOLD
Exedy Stage 2 Clutch + Exedy Flywheel less than 2k miles $250 SOLD
63mm T1R Exhaust $300 SOLD
ITR Valve Cover $100 SOLD
ITR Stock Intake $80 SOLD
ITR Engine Harness $125 SOLD
ITR Injectors $50 SOLD
ITR Amber Radio $90
ITR Axles with Intermediate Shaft $125
Alternator $80
Vtec Solenoid $50 SOLD
Radiator w/o fan $30
Starter $100 SOLD
Distributor $125 SOLD
ITR head w/ everything below except cams/gears $600 SOLD
-Skunk2 Pro2 Cams $400 SOLD
-Skunk2 Stage2 Cams $300 SOLD
-Skunk2 Pro Cam Gears $100 SOLD
-Supertech Bronze Valve Guides
-Supertech Stem Seals
-Supertech Dual Valve Springs
-Supertech Flat Faced Valves
-OEM Retainers
BLOCK SOLD
B18C Block
84mm Darton Sleeved
Carillo K1 Rods
JE 11:1 Pistons
ACL Bearings
ARP Mainbolts
LS Crank
TRANNY SOLD
00 ITR
Exedy Flywheel
ITR Amber Radio $90
Alternator $80
Starter $100 SOLD
-OEM Retainers
how much for the supertech dual springs??? also, how many miles does it have on them???? let me know!!!
I believe all PMs were replied. PLEASE PM me if I missed you. I just picked up all of my parts so I can send you picture messages asap.
how much would u sell Supertech Bronze Valve Guides, Supertech Stem Seals, Supertech Dual Valve Springs, Supertech Flat Faced Valves for?
Everything sold fairly quickly... just have to get rid of a couple more things... Dont be scared to shoot me some offers.
