wanna boost my d16y7
got a 96 civic hatch and wanna add a turbo.. i know i need a y8 intake manifold and obviously a turbo kit. this is my daily driver and im not racing it just want some more go when some jerk cuts me off..... what do i need for like 8 psi for injectors and ecu... will upgrade motor down the road i just want a starting point
For 8psi you are going to need low compression pistons, 750cc injectors or bigger, hondata or some other expensive ecu, you'll need the head to be built with aftermarket springs/reatiners, a turbo cam, the block needs to be sleeved, you'll also need a 6-puck clutch and lightened flywheel. You're also going to need an LSD transmission or else you'll get massive amounts of torque steer that is going to kill you.
Swap a D16Z6/Y8 head or swap in a whole D18Y8 to start with. Just a little kick for vtec.
DD with it then turbo it, I'd suggest the Z6 head if doing a mini-me swap. It flows better. Since you are going to have a long *** tranny already. Turbo is an +.
Just do some research in the F/I section and you'll be amazed
okay yes, low compression pistons, 750 cc injectors are fine but 440s will do, crome chipped ecu is cheaper and works fine but hondata is better. crower makes CHEAPER and reputable cams, valve springs, and retainers. block doesnt need to be sleeved for 8psi of boost, a block guard will do. sleeving isnt a bad idea though if your going 12+ pounds in the future. you dont NEED a 6 puck clutch or lightened flywheel, trust me, on a single cam, 6 pucks are tranny killers, just an aftermarket stage 2 kit should be fine, such as ACT or Exedy. and an LSD tranny is not an absolute necessity for 8 psi, although if you have the extra cash, buy one why not
first off, 8 psi means nothing without taking into consideration the size and volumetric efficiency of the turbo intended on being used. 8 psi on a 57 trim t3/t4 is not the same as 8 psi on a gt35r. lower compression pistons are NOT needed for a low amount of boost on a small turbo. an upgraded valvetrain and block guard are also NOT needed. you only need to worry about sleeving if you're aiming for a 300hp range or higher. and anything over about 220hp it's highly recommended you upgrade the stock tiny *** rods. notice how the necessity of a given component is based upon a hp range, not an amount of boost.
you can boost that y7 with 8 pounds and will be fine just use 91 octane and minor tune and it will be ok, now the down side is the newer model single cams have crappy oil pressure compared to the 92-95 models you could do some engine mods to aid in this aspect but as you said you want little more power with out messing up reliability so just install it right and be careful
There is a dedicated 'forced induction' forum for turbo setup's, etc. Lot's of information to be found in there, but since all the replies have been somewhat informative.. I will not lock this. OP you need to do some research, lot's of research.
i think the guy you quoted was being sarcastic.. or atleast i hope he was. sarcasm seems to run rampant here, much like misinformation.
Browse the hondamarketplace. Also check under the sponsors section. There are companies that sell them.. pherable, etc
cheapest thing you can do is get a chipped ecu from somewhere like xenocron or phearable, or as the guy above said try to pick something up from the marketplace.
http://www.phearable.net/ecutuning.html
then bring it to a shop that tunes with neptune, crome, etc and they will be able to get it set up for you.
this is for a b-series but the same steps still apply for d
https://honda-tech.com/forums/forced-induction-16/complete-how-turbocharge-your-honda-rep-ing-hypnotik-speed-1263795/
if you stay stock internally then don't go over 220hp. if you want to do more then that then pick up some vitara pistons and eagle rods.
BTW, i'm really tempted to lock this because you're not really getting a lot of help...if anything, this information is further obscuring your goal
indeed^ with stock rods you don't want to be going past about 220hp. with aftermarket rods you could do 450hp+ safely. after looking around i've found numerous builds and videos of guys running these kind of numbers on stock sleeves. which is now part of the reason why i don't think i'll going be spending the money to sleeve my z6 for the vitara build. just don't think i'm going to need more hp then what stock sleeves can handle.
anywho. here's a stock sleeved d16 making some impressive numbers..
http://www.youtube.com/watch?v=J-CvdlJLes4
ferdiepinoy
14
Jun 11, 2010 05:03 PM
