WTB ASAP HEADLIGHT/TURN SIGNAL SWITCH
jimmy no offense but they are deffently different. I just tried to put a 92-95 steering column in a 99-00 and I couldnt resuse the multifunction switch. the 3 bolts that hold it to the shaft are closer together and the other is furthour apart.
Why would an eg and an ek have the same steering column all I said was the headlight switches were the same i've used eg switches in eks before theY work exactly the same and fit the same. Same can be said for the wiper switches
That's what I am telling you though. I actually got the column in and it worked but the wiper switch wouldn't go in and the plastics wouldn't work. You could probally take it apart and use the base but if you use the whole assy it won't work.
0utaSight
Northern California (Sales)
Nov 15, 2006 11:09 PM
