BSERIES everything must go out of the BIZZ
BUILT GSR BLOCK 95' legit with paperwork------pending
-81mm JE pistons
-over sized h-beam rods
-acl bearings
-arp rod bolts and head studs
-micropolished crank
-honed and hot tanked turbo ready
-cometic headgasket
95' GSR head --------pending
-blox dual springs, retainers, flat face oversized valves
-gsr cams, cam gears and valve cover
-hondata intake gasket
99' b16 head-------700
-crower retainers dual springs jun valves
-port n polish
-jdm valve cover cam gear cut out
-aem cam gears gsr cams
98' Integra Type R Transmission LSD---1200
-less then 1000 miles MINT
Jackson Racing Supercharger b16/ITR-----1100 to 1450 depending what you need
-blower/manifold
-belts
-all pulleys
-moded alternator with mvm stepper
-4.2 and 3.8 nose pulley
-fuel rail adapter for FPR
-JG 65mm TB with TPS and MAP
-Precission 440 injectors
Hondata s300 p28----sold
-TUNED for 10psi Jackson racing supercharged b16 230whp 144tq
Hytech Replica header------350
-brand new never used
-4.2.2.1 stainless header tri-y
-2.5 donut collector
-brand new header gasket
95' GSR transmission----sold
-never used it bought it with a complete stock gsr swap
Spoon Replica CF lip EG---250
-brand new
2200 dual pressure plate and 6 puk sprung clutch----sold
-used low miles
Used msd complete setup pro cap, blaster 2, 6al box ,and including obd 2 dizzy b16 or gsr od1 dizzy ----pending
-all wired and ready to go
obd2 to obd1 distributor conversion harness-----sold
Ported Type r Manifold------200
Oem honda steering wheel air bag intact---50
kazz lsd 4.7 final gear only----50
Oem GSr header 2.5 collector---35
Avid B series mounts used (eg/dc)---sold
Samco black radiator hoses b16---Pending
Sandwich oil filter adapter plate---SOLD
Stage 4 Buddy Club Cams----400
GSR intake manifold with fuel rail injectors throttle body---50
97 ITR LSD Only-----250
_OR BEST OFFER_
SERIOUS BUYERS ONLY
7606506963 call or text
**everything must go QUICK**
PLEASE DONT WASTE MY TIME
~pics upon request
-81mm JE pistons
-acl bearings
-cometic headgasket
-port n polish
-blower/manifold
-belts
-all pulleys
-brand new
-used low miles
_OR BEST OFFER_
SERIOUS BUYERS ONLY
~pics upon request
this
