2000 Accord Brakes
I own a 2000 Accord 4cyl Coupe. Every time I use my brakes at a slow speed it makes a loud scrapping sound and my car vibrates (my brakes/rotors needs replacing).
I believe the car has front disk brakes and rear drums? Can anyone confirm? Also can anyone recommend what brake pad/rotors I should get? Either I get OEM Honda, or maybe hawks brake pads and power slot rotors?
Thanks
Steve
Thanks
Steve
just go look at your front and rear brakes through the wheels. if they look basically the same then they are all disk, if the rear ones look different then you have rear drums.
i thought the newer accords all had disk brakes front and rear but i could be wrong on that for sure. i know in 94-95 ex's were the only ones that had all wheel disk brakes.
tell us what trim model you have and someone will be able to tell you exactly what you have.
mikec35
May 25, 2014 08:31 PM
straightliner1
Nov 20, 2007 03:17 PM
