civic alternator?!
Old Feb 12, 2010 | 08:48 PM
vtecx2's Avatar
Default civic alternator?!
so a few days ago all my lights and stuff were on a constant flucuation dim birhgt dim bright exc. exc. so i look at it and a hold the alternator was loose and somehow grounding to the block which was causing it to do what it was doing....i pushed it back in hand tightened it a little just go get it in. and the lighting problem stopped. so today im warming up my car and everything dies. i look again for that bolt and its gone... is this why my alternator is gone right now?? is it some sort of a ground? help please!!! i mean it has to do somthing seeing as it just being loose and getting close to the block it was sparking and causing my lights to dim and bright,,,,,,right??
Old Feb 12, 2010 | 10:09 PM
vtecx2's Avatar
Default Re: civic alternator?!
does anyone help you out with anything on here wtf?
Old Feb 13, 2010 | 12:10 PM
vtecx2's Avatar
you people are useless
Old Feb 13, 2010 | 12:25 PM
CivicSpoon's Avatar
We're useless because you don't know how to tighten your alternator down properly?
Try getting a service manual and a multimeter, and then go through the process of reading the wires to the alternator; to see if there's a problem. It could be a damaged wire somewhere or it could be a bad voltage regulator.
Old Feb 13, 2010 | 12:31 PM
keving85's Avatar
I would disagree. I am not useless I am holding this couch down damn good if you ask me!!!!! Lmao. But yeah what civicspoon said. Try that
Old Feb 13, 2010 | 05:31 PM
vtecx2's Avatar
Sorry bout the useless thing guys=/ just fusterated....not in a good spot right now...u no? but alright ill do that thanks man
Old Feb 14, 2010 | 03:55 PM
vtecx2's Avatar
Got it fixed guys one of the bolts from the alternator bracket actuallly fell out,,,and shifted the alternator i guess just enough to make it not spin as fast and not produce power.
Old Feb 14, 2010 | 03:57 PM
honda.driver.bence's Avatar
maybe try using some loctite
Old Feb 14, 2010 | 04:13 PM
thumper64's Avatar
Great idea. Never loc tite something like that down. Either torque them or replace your bolts with longer ones and double nut them.
Old Feb 14, 2010 | 06:59 PM
vtecx2's Avatar
well i cant actually get it to thread into the bracket tho...stripped maybe?? or is it normally hard to thread it into the block due to the tension?? or you guys think i need a new bracket...?stripped?
Bradford86
Honda Civic (2001 - 2005)
Mar 5, 2019 11:13 AM
92silude
Jun 14, 2005 12:11 PM
Scubster
Aug 13, 2004 08:37 PM
strikenlite29
Jan 2, 2004 09:36 PM
