Anyone loaded a motor into a pickup truck using an engine lift?
Old Sep 6, 2002 | 09:33 AM
ScottEK's Avatar
Default Anyone loaded a motor into a pickup truck using an engine lift?
I'm very worried that the lift won't go high enough to get it on to the truck's bed. Does anyone know how much a ZC weighs approx.? Only thing I've read is that it weighs very close to the SI engine so if you know it's weight that would work. Thanks
Old Sep 6, 2002 | 10:07 AM
rex_boy's Avatar
Default Re: Anyone loaded a motor into a pickup truck using an engine lift? (beta13)
probably around 350 including tranny. I loaded one in a NISSAN 2X4 PU.
Old Sep 6, 2002 | 10:32 AM
SpooN Man's Avatar
Default Re: Anyone loaded a motor into a pickup truck using an engine lift? (rex_boy)
It only took three people to lift my entire b16a swap with tranny attached into a pickup.
[Modified by SpooN Man, 2:32 PM 9/6/2002]
Old Sep 6, 2002 | 10:37 AM
Finest's Avatar
Default Re: Anyone loaded a motor into a pickup truck using an engine lift? (SpooN Man)
Bah! Try an H22 from the floor to a van! Only took two guys, me and my brother.
Old Sep 6, 2002 | 12:28 PM
LS-Rt's Avatar
Default Re: Anyone loaded a motor into a pickup truck using an engine lift? (Prelude_RCR)
It might be tough because you can only make the chains so short but I think you should be able to do it. Unless you're loading it onto a tall 4x4 which would suck
[Modified by LS-Rt, 9:28 PM 9/6/2002]
Old Sep 6, 2002 | 01:21 PM
SuperCivic's Avatar
i've loaded multiple motors in multiple trucks. never had a problem. just as long as you're not trying to lift it up into Big Foot or Gravedigger you won't have a problem.
Old Sep 6, 2002 | 01:22 PM
keebler65's Avatar
Default Re: Anyone loaded a motor into a pickup truck using an engine lift? (LS-Rt)
it depends on the lift i guess but i had no prob getting it into a high chev. that was a b16 too which i would guess must way a little more
dfoxengr
Welding / Fabrication
Dec 20, 2006 05:52 AM
kgard
Nov 8, 2005 05:25 PM
drjondurst
55
Mar 19, 2003 09:00 PM
GruvyTune
Sep 25, 2002 07:02 AM
