Holley 68mm Throttle Body
Ok I got the jg victor x intake mani and the holley throttle body at the same time.... the throttle body was replaced twice already and both have the same issue..... the flange sticks and the car idles 12-1800..... and every so often... right after redline is hit and the accelerator released the car goes funky.... jumps between 1400-1600 non-stop. The throttle cable has also slipped off halfway several times. We installed a second spring but it still doesn't close properly.... I know the holley 68mm was a limited release because holley told me that they only sold about 48 of them so far and have had a few issues. I am thinkin about replacing it with the bbk 70mm. Does anyone have any experience or thoughts on the bbk tb?
why not try the ones inlinefour.com supplies now? u have a choice of a billet replacement, or a bored out stock t-body. they give u a new butterfly when u bore urs out too. as for the tps adjustment, use the sensor check on the vafc if u have one. that should help a lil. good luck guys!
krazy
krazy
LSVTEC 91 Civic
15
Oct 28, 2005 06:16 PM
mkinpwrat12g's
Sep 1, 2005 07:12 AM
