need 6th gen ecu info
Old Feb 11, 2010 | 10:08 PM
LAEGER525R's Avatar
New User
Default need 6th gen ecu info
I have an 01 thats a 4cyl 5spd & it has a bad ecu. Can I use any 4cyl 5spd ecu from 98-02..?
Old Feb 12, 2010 | 04:07 AM
triggerman77's Avatar
Default Re: need 6th gen ecu info
That should work as long as it came from a 4cyl 5sp car. Also i have the one from my 99 that is 4 sale LMK if you cant find one local. I have the complete drive-train 4 sale also.
Old Feb 12, 2010 | 10:24 AM
LAEGER525R's Avatar
New User
Thanks for the help. I should add that mine is the F23a4-ULEV. Are the ecu's the same a1,a4..? What ecu do you have?
Old Feb 12, 2010 | 11:10 AM
GhostAccord's Avatar
No you need a ULEV ECU. The regular ECU's are not equipped with the extra emissions capabilities.
IIRC the ECU part# that you are looking for is 37820-PAA-L23. Any OBD2 ULEV 2.3L 5spd ECU should work
Old Feb 12, 2010 | 02:09 PM
LAEGER525R's Avatar
New User
Thanks for the help.Yes,my vin# calls for a L23 ecu.I have found a L22 & L20,they are from 5 speed cars but cant seem to find out if the motors were ULEV..? Are there any web-sites that can give info on part numbers?
Old Feb 12, 2010 | 03:08 PM
Mine is a 99 F23a1 5sp PAA-L11 ECU. mine is LEV NOT U-LEV. Not sure if it will work for u.
I also have a PCF ECU.
Old Feb 13, 2010 | 02:58 PM
g22aOnBoost343's Avatar
it will work. the only problem u have is rechipping the ecu at a honda dealership because our cars come with transponders. being ULEV or not won't really be affected by the ecu.
jitarub
Honda Civic (2001 - 2005)
Apr 18, 2016 12:54 AM
rutchiesan15
Jan 10, 2013 12:39 AM
