Suspension & Brakes Theory, alignment, spring rates....
4x100 vs 4x114?
Old Feb 11, 2010 | 09:30 PM
wite2nr's Avatar
Default 4x100 vs 4x114?
Is there a difference between 3rd gen integra brakes and a 96 spec 4x114 set up? I am getting conflicting info.
Old Feb 12, 2010 | 05:49 AM
phunhaus's Avatar
Default Re: 4x100 vs 4x114?
As for size, No. The pads and rotors are the same size.
Old Feb 12, 2010 | 12:17 PM
jr_deleon's Avatar
What exactly have you heard? The bolt pattern is different (4x114.3 is the same bolt pattern as the 90-02 Accord 4cylinder, 92-96 Prelude, and several other cars while the 4x100 is of the Civics and Integras 4 lug) but has the same sized rotors and pads as the DC Integras (3rd gen, 94-01 Non-Type R)
Old Feb 12, 2010 | 02:31 PM
wite2nr's Avatar
conflicting info in regards to the caliper/rotor size. thank you for the clarification.
Old Feb 12, 2010 | 02:54 PM
jr_deleon's Avatar
Here is your "to end all debates" link so if you want to even buy the rotors here's an option
http://www.fastbrakes.com/category_s/4.htm
Old Mar 17, 2010 | 11:22 PM
homansem1's Avatar
what brake pads would you use if you have the 4x114.3 conversion??
i heard the dc2 ones work do they??
Old Mar 18, 2010 | 05:41 AM
phunhaus's Avatar
Yes, regular non-Type R pads work.
Old Mar 18, 2010 | 11:50 PM
homansem1's Avatar
ok thanks man
maxogsr
Suspension & Brakes
Nov 1, 2014 03:44 AM
DC2R82
Mar 24, 2012 10:48 PM
4F_ Mugen CoL
25
Sep 6, 2007 03:37 AM
botlebruiser
10
Oct 31, 2006 02:12 PM
nickwilmot
Sep 5, 2003 12:00 PM
