HX Manual Transmission substitute
Old Feb 11, 2010 | 04:43 PM
rharlow's Avatar
New User
Default HX Manual Transmission substitute
Can I use any D series 5 spd in my 1997 HX D16Y5. Thinking I have transmission problems (making noise in first) so looking to get prepared in case I need to swap out and put another one in. Could I use one out of a EX instead? Thanks
Chip
Old Feb 11, 2010 | 04:45 PM
DVDr's Avatar
Default Re: HX Manual Transmission substitute
to make it simple,
Any transmission from 1996-2000 is a bolt on ( from personal experience ).
But the transmissions from previous years ( 92-95 ) will also bolt up and work.
-- so basically any hydraulic D series transmission will work for you --1992-2000
Old Feb 11, 2010 | 04:52 PM
94EG8's Avatar
Seagull Management
Correct
If you want something geared similar get a '92 - '95 CX/CX tranny. HX trannys are kind of an oddball, they're geared long, like a VX tranny, but they use a big bearing case/diff like an EX/Si.
Old Jun 7, 2012 | 08:57 PM
98EJ7Y8's Avatar
so a hydro 98 hx transmission case will fit a hydro 96-00 ex trans ?? both manual of course
Old Jun 8, 2012 | 12:30 AM
Axatax's Avatar
As long as this not a CVT (and I assume it's not since you specified a first gear), then all the usual swap how-to's apply. The CVT requires a custom transmission mount.
Old Jun 8, 2012 | 09:29 AM
Hidenplanvew's Avatar
well since cvt is an automatic and were talking about 5 speeds....You can make a custom geared hx trans if you wanted.
With a noise in first are you talking stoped at a light with clutch in or taking off from a light? Also have you tried to change the fluid in it with new honda MTF?
Old Jun 8, 2012 | 12:09 PM
91 EF DX's Avatar
Are all the splines the same in 92-2000 5speeds? And are the mounts the same too?
new_climber
Mar 6, 2013 03:22 PM
goula SOS
13
Sep 10, 2003 01:08 PM
HXMan
Sep 6, 2001 06:26 AM
94hondaman
Aug 11, 2001 05:03 PM
