katzenjammer84's 1992 Accord Restoration
This car is a money pit, replacing everything as it breaks. All it's life Arizona car, absolutely devoid of rust but definitely neglected and desert beaten. Will eventually be better than new, receiving H22A/5MT swap 6/11 and a full chassis/body down to metal respray 8/18.
Pretty **** picture but everybody knows what a stock Accord looks like.
And the car I will probably blatantly copy, a little dub influence in the style.
Done Thus Far
Six 195/60-15 tires (awful toe problem)
Four Rotors/Pads
Air Filter
Cap/Rotor
Rear Swaybar Endlinks
Acura Vigor Swaybars/Brackets
Spark Plugs
Spark Plug Wires
Oil pan gasket
Battery
Four Tail Light Gaskets
Four '96 Acura 2.5TL Wheels
Valve Cover Gasket Kit
Valve Adjustment
All Major Fluids Changed
Passenger Tail Light Harness
Steering Rack
Rear Upper Control Arms
Oil Cooler Replaced
Positive Crankcase Valve
Radiator Overflow Bottle + Cap
Lower Radiator Hose
Four new lower rear control arms w/new Hardware
New rear subframe
Currently
JDM H22A Swap
5MT Conversion
Apex-i WS2 exhaust
HKS Super Megaflow Intake
Future
KW V2 Coilovers
Repainted Refrigerator White
Summer Wheels/Tires
New glass all around
New trim all around
New headlights
Cloth Swapped Interior
Front Lip
Tint
Done Thus Far
Four Rotors/Pads
Air Filter
Cap/Rotor
Spark Plugs
Spark Plug Wires
Oil pan gasket
Battery
Valve Adjustment
Steering Rack
Oil Cooler Replaced
Lower Radiator Hose
New rear subframe
Currently
JDM H22A Swap
5MT Conversion
Apex-i WS2 exhaust
Future
KW V2 Coilovers
Summer Wheels/Tires
New trim all around
New headlights
Front Lip
Tint
Hey, loving the idea for this build. Your "inspiration car" is straight Jessica-Simpson as well. I'd John Mayer it.
I usually don't try to sway people away from their decisions or plans for their car. However, this is a public forum, and by posting here, you did open yourself up to public opinion and scrutiny.
That being said, I would like to strongly encourage that you re-think spending $4800 on your paint job. With proper sanding and prep, your local Maaco could set that thing up right for $300 to $1200, at the most, and give you an excellent and professional paint job. You could then spend the other $3000 (wow, this sounds crazy even typing) on other things, like an engine swap, wheels, etc... and have the whole build practically done for the cost of your original paint allotment.
Either way, best of luck!
This includes doing all the door jambs, pulling all glass and trim, and bringing the entire car down to metal. It's a lot of work, and frankly for the effort he will be putting in he is cutting me a deal.
Maaco would scuff it, which given the age will not be durable. It needs to be brought to metal and reprimered. Like I said, it's essentially being restored, the right way.
I don't need crazy money for performance stuff, a set of a KW V2's and some widened D Window steelies are about it for this thing. The rest of my time is refreshing OEM equipment.
Going to metal I agree with. And from what I've seen, that's a decent price. Considering they are going from SCRATCH at that point.
As for those rims, those are Diamond Racing Wheels. They will run you roughly 3-500 dollars for the set depending on sizes, offsets, etc. His, chances are, are custom painted with that polished lip. But yea, have fun with it.
Little update.
Long story short the engine went. I ordered a JDM DOHC F22B along with a 5-speed manual transmission. Going to be swapping in the next few weeks, will probably end up doing a H22 head swap and a 'lil boost when she's out of paint.
Motor pulled, sold the F22B and am picking up a full changeover H22A/5MT from hmotorsonline instead. Will be done by 2nd week of June, then off to paint in August she goes.
JeffyHfx
May 18, 2008 10:39 PM
