Fellow R owner's chime in....k20a or f20c
What do you guys think of either swap. Now i know most of you are diehard owner's and would rather not see anything other than the original C5 in a R but i dont have the option of having my original block or tranny. With that said what do you guys think of either swap? I've seen people do k20r's and i myself have done a k-swap on another member's Itr but i've never seen or heard of an f20c powered R.
What are the pro's and con's of both?
k20s have a larger afternarket for power mods ie cams, headers etc, k20 would cost less then f20 theres many reasons to choose the k20 over the f20
people the f20 to say they have a f20, if you really want power and performance get the k20
Depends what you are after.
You can run a bone stock K24A1 block/head w/ cams, RBC, header, K20 TB, KPRO and make over 200whp (yes, thats right, no K20 head). The engine will lump like TODA VTEC killers.
K24A1 engine = $550 shipped
RBC manifold = $150
KPRO = $800
Chinese Header = $300
K20 TB = $125
Si Tranny w/ LSD = $1000 shipped
Cams = $400
K20 Oil Pump = $125
Total = $3450
Mounts = $400
PnP harness = $300
Axles = $400
Shifter box + cables = $300
Total = $1400
Total Swap Price = $4850
None of the above is "poor mans" setup. There are a few drag teams that believe using the K24A1 head as opposed to the K20 head due to its flow design. This motor setup listed above will rock your world.
There is more R&D with K's than there are J's at this point. You can actually close your hood with a K as well.
F20C is a very expensive platform. There are not too many people running that, actually, I cant even name one person doing F20C setup. IMO, its not worth doing the F20C because the K platform is already dominate with large amounts of WHP/TQ.
RBC manifold = $150
KPRO = $800
K20 TB = $125
Cams = $400
K20 Oil Pump = $125
Total = $3450
Mounts = $400
PnP harness = $300
Axles = $400
Total = $1400
258 hp @6500 223 ft/lbs
http://www.youtube.com/watch?v=1rE1tK1Q1sM
No need to go threw all that building you mentioned, move one mount, wire it up and go.
Personally, if I had a complete R, minus motor/tranny, I'd either put a K24 in it or I'd get a B18, build it for boost and turbocharge it.
Or, I'd look for JDM B18C5 complete motor/trannys.
I don't like the idea of a motor swap that causes compromises and engineering issues, such as the F and the J swaps.
Honestly, you'll probably be much happier if you keep it simple.
you know what I am after, keeping it simple. Close to stock and reliable. Heres a vid posted by Wolydotmatrix as an example.
You need to see this. DC hoods close. I got you covered already brotha.
JDM front
Originally Posted by gargsta
Originally Posted by andyjt
June: 2009
After the expo, i realized my caR was slow. I wanted more, something that HASNT been done. I tossed around the idea off and on between this and a K swap. Either way i wanted MORE!
July 2009:
Engines out and swap is being sold/ parted out.
August 2009:
I purchased this from Copart.
Sept 2009:
No turning back anymore :-P
Mid Oct. 2009:
Progress, its going in/ its IN! Ground up running in 3 weeks( working 40+ hour work weeks!)
Oct 17th 2009
It RUNS! After about 2 1/2 weeks from recieving the donor car, shes up and running strong!
Early Nov 2009
The Modding Itch began, and one requirement was a HOOD. I absolutly REFUSED to cut my freshly painted hood to but a huge *** hole in it.
Nov. 2009:
Hood Closes!
Thanks for looking. More updates will come as neccessary.
-Andrew
personnally id probably just throw in a b18c5/jdm b18c. sure you can go faster with other set ups but its still plenty of power to have fun with
If it is a drag car, then fine. But a car that'll see autox and track events, no thanks.
