Honda S2000 Honda S2000
Need help with my s2000
Old Feb 11, 2010 | 02:22 PM
s2000boyyee's Avatar
Default Need help with my s2000
I have an 02'. The reservoir for the radiator fluid constantly goes empty and the car sometimes overheats. I checked oil, nothing leaking inside. I checked the radiator, nothing leaking. No leaks coming from under the car. No leaks inside of the car. I have no idea where the fluid is going. I'm curious if the heater might have anything to do with it.. Any insight as to what the problem could be?
Old Feb 11, 2010 | 04:01 PM
91redteg's Avatar
Default Re: Need help with my s2000
hmm could be a slow leaking headgasket are you getting any white smoke?? or check the carpet in the car under the dash maybe heater core or look for very tiny leaks in the radiator
Old Feb 12, 2010 | 08:53 AM
Na I thought that's what it was too but there's no smoke and my uncle did a compression test at his shop. I also checked the heater core and all that stuff but found nothing.
Old Feb 12, 2010 | 09:50 AM
mustclime's Avatar
blown head or cracked head or block. Check your pluggs, one ormore of them will look different.
Old Feb 12, 2010 | 09:52 AM
yeah I'm thinkin that too -_-
Old Feb 12, 2010 | 10:09 AM
mustclime's Avatar
get a leak down test.....bubbles in the coolent will prove you have a leak.
Old Feb 12, 2010 | 10:28 AM
oh alright i'll check into that. thanks.
jxhxb
17
Jun 27, 2010 03:17 PM
oddmut
11
Jul 8, 2007 10:48 AM
zero2hero
Jan 30, 2007 08:49 PM
Scubster
Jan 4, 2005 01:04 AM
confucius
Sep 2, 2001 09:22 PM
