What OBDII Scan tool do you use?
Old Feb 11, 2010 | 10:44 AM
pk386's Avatar
Default What OBDII Scan tool do you use?
Hey all.
I'm interested as to what do you guys use for an obdII scan tool?
I was wondering if there was a decent scan tool out there that would issue commands in some of the newer cars. (like when you bleed the brakes you can issue the command to activate the ABS pump to properly bleed them Or crank shaft position re-learn on GM's)
Thanks
MT
Old Jul 13, 2010 | 01:50 PM
pk386's Avatar
Default Re: What OBDII Scan tool do you use?
Bump
DC2Projektz
Oct 25, 2007 11:15 AM
t . b o z
Apr 29, 2005 09:58 AM
