Does this work?
Old Sep 6, 2002 | 07:36 AM
E. Honda's Avatar
Default Does this work?
http://www.jdmfan.com/technical/perf...advancedtiming/
Old Sep 6, 2002 | 07:45 AM
owen_the_soyboy's Avatar
Default Re: Does this work? (CDM SiR)
yah it "works"... but that depends on what you expect from the change.
I tried different settings on mine a little last month to try removing a dip in my power band at vtec. I am running a stock GSR motor, JUN ecu, aem cai, spoon header, testpipe, 2.5" piping and N1 muffler. With a little advance on the intake cam the car now pulls harder and much smoother. Now when I am cornering while vtec kicks in the car is much more stable.
Old Sep 6, 2002 | 08:14 AM
E. Honda's Avatar
Default Re: Does this work? (owen_the_soyboy)
Are there any risks of doing this? I have a B16a2 \i\h\e
Old Sep 6, 2002 | 08:20 AM
the risk of playting with your timing is detonation aka pinging.
when your motor ignites the air/fuel mixture before it should, because of temps and timing settings.
if you dont have a noisy exhaust you can usually hear pinging as a fluttery piece of metal sound... like what you might think a throttle body plate would sound like if it was bouncing open and closed a thousand time a mintue.
the article you linked to explains how you want to remain WITHIN +/- 2 degrees of your stock settings to avoid detonation/pinging.
detonation/pinging is a surefire way to eat up your headgasket with extreme temperatures and cause a major problem when the headgasket fails.
AznBlueBoy
Feb 17, 2014 12:23 AM
tianporn
28
Apr 18, 2005 12:37 AM
zensoku207
Mar 21, 2005 10:49 PM
willahlborn
Feb 17, 2005 09:54 AM
JunIntegra
Jan 9, 2004 04:43 PM
