Which Axles for B16A in an EG?
Hey guys, I searched, couldn't find too much concerning what I'm looking for. I was just wondering what axles to buy if I have a B16A swapped into an EG. Will any EG axles fit? I basically want to be able to tell the guy at the parts counter exactly what I need. Thanks in advance
Can we be a little more specific...Maybe include a year in your description...I'm not an Integra guru or anything, so unless all Integra's use the same axle I'm going to need a little more guidance.
I told them 95 acura integra LS axles. Depending on whether or not you have ABS, you can order them with or without ABS rings, I got mine without the ABS rings on the axles, much cheaper.
the core for em1 axles is a slightly higher than axles for an integra
integra:
http://www.autozone.com/autozone/cat...&parentId=12-0
em1
http://www.autozone.com/autozone/cat...equestid=37124
integra:
em1
last time I got axles at autozone they were 59.99 for new ones no core, I think they finally quit rebuilding those POS axles of theirs, not hating I use them but if they didn't have the lifetime warranty I wouldn't touch them
gl
gl
Cause if you looked just a little bit harder you would of found this
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5Dlots-swap-info-your-eg-del-sol-983454/ i didnt even search its a sticky!
