Transmission & Drivetrain Gearboxes, Differentials, Clutches
when replacing a clutch what else do i replace
Old Feb 10, 2010 | 09:27 PM
civichatcheg6's Avatar
Default when replacing a clutch what else do i replace
Im about to put a ACT stage 2 clutch in, i didnt buy it i traded some headers i didnt need for it, but i was wondering if i need to change the flywheel also and if i need to change anything else when i put that clutch in. im not running anything special its a d15b7 block with a z6 head. thanks guys
Old Feb 11, 2010 | 03:21 PM
BrandonR's Avatar
Default Re: when replacing a clutch what else do i replace
I'd get the flywheel resurfaced and the pressure plate resurfaced for a smoother engagement. Although its not a "you have to do it" type thing. And if it didnt come with a throwout bearing or pilot bearing, I'd replace them too. When I did my clutch I replaced everything since it came with the kit, but I didnt resurface my flywheel. Only thing it does it chatter a bit before lock up.
Old Feb 12, 2010 | 07:47 AM
93LsVx's Avatar
If I were you, id get a lightened flywheel for that mini me. No sense in a stage 2 clutch with a 22lb flywheel, ya know?
Old Feb 14, 2010 | 12:27 AM
Thmanx's Avatar
22lb?
when i replaced my OEM for an ACT Stage2, I weighed my B16 (P30) flywheel, it was 17.5lb...
Old Feb 14, 2010 | 10:01 AM
unusual71's Avatar
i would get a new flywheel personally
otherwise its pretty important to resurface the flywheel if you want the clutch to work like its supposed to
shakkamatt
Jan 1, 2009 03:09 PM
mattmw88
Jul 30, 2007 02:23 PM
IntegraMastaz
Dec 13, 2005 05:26 AM
typer_801
Apr 24, 2002 05:41 AM
JohnR265
Oct 12, 2001 04:16 PM
