positive ground k20z1!!!!
So I went to put my battery in my car after working on it and found that the positive wire is grounded. Anyone with electrical experience know the best way to go about trouble shooting this? I checked all the grounds on the car and everyone is solid. YES the positive wire is connected to the positive wire on the battery. Im pretty sure I narrowed it down to some kind of ground or short on the positive side but no idea where to start hunting it down.
not sure if this would help, but I had somewhat of similar trouble in the past. I did some bolt-on mods along with bodykit and headlight assembly replacement. When done, reconnected the battery, doesn't work..., checked all the ground, connections, and yes the +2+ & -2-... Nothing. f*ck this and took a lunck break sitting down on a stool looking directly at the front of the car and found something fishie, and it turned out that I grounded the wire onto what at the time looked just like a metal piece where the new body kit and headlight assembly were just installed, lol. Relocated the ground, problem solved. I know it may sound shootupid, but I swear it looked just like a metal frame portion of the car. lol...
