Bad ball joint, a question.
I have a ef8 sir and the lower ball joint is starting to have some play. I do not want to press it out if i don't have to. I have a complete set of front spindles for a 90 integra. Can I just swap the stock b16 spindle for the integra one and not mess up my alignment?
So are the b16 spindles and DA spindles the same, i guess is what i'm asking.
I will get an alingment done i just want to be able to drive until I can get my car in then lined up. I don't want the camber or toe to be way out that i can't drive it.
the balljoint isnt really that hard to get out....ive done it quite a few times. theres a snap ring to remove the a few good whacks itll pop out. a torch with some heat works well. use a good size socket to install the new one.
