DelSol cluster help.
need some help.
my 1993 DelSol S cluster lights doesnt work and the climate control lights also dont work. But when I switch out the cluster with a friends one from another delsol everything works fine. could it be the cluster and if it is can I fix the cluster or do I have to buy a new one?
The heater control lights going out is a real common issue as long as its just the back lighting. The green LEDs never go out. If they have, you have an odd issue. Otherwise, pull it out and replace the two bulbs.
The cluster... Check the bulbs on the back to see if they're good. If not, you might have a cut somewhere on the plastic circuit board. If they are burned out, replace them as needed.
I have a couple sol clusters in pieces that will never go back together, so if you need parts, PM me and I'll see if I can help you out.
b16_coupe
Nov 16, 2012 01:32 PM
