Question bout LS-V build
ok so i had one simple quesiton,,..
i have the whole long block of a B18b motor and the whole motor swap of b16a2
and i wanted to put them together for an LS-v..
i was wondering could i use the pistons from the b16 cause they should be p30 right??
and wat all will i need else to do this ls v?
thanks
thanks
pistons aren't p30's, but pr3's (the american version)
you can find lsv conversion kits that will give you everything you need minus labor to do it. (i.e. golden eagle sells one, but you can find others for cheaper!)
94civicexlsvtec
Nov 10, 2004 07:31 PM
