Suspension & Brakes Theory, alignment, spring rates....
NEED SPRING RATES
Old Feb 10, 2010 | 03:07 PM
eg515's Avatar
Default NEED SPRING RATES
found the info needed thanks guys
Old Feb 10, 2010 | 03:23 PM
known's Avatar
Default Re: NEED SPRING RATES
why dont you just get custom rates from eibach/ground control and then some konis, tokikos etc?
Old Feb 10, 2010 | 04:05 PM
.Manny.'s Avatar
Touching My Member
those spring rates are way too high for ots konis or tokicos.
Old Feb 10, 2010 | 04:44 PM
known's Avatar
and the 800 dollar omni drags actually were?
the brands he mentioned i dont believe can handle those rates either especially not in the price range they are in...could be wrong but i really doubt it.
Old Feb 10, 2010 | 06:33 PM
.Manny.'s Avatar
Touching My Member
I'm not saying that they weren't for the omnis either. I'm just stating a fact. OP, ask around in the drag racing section to see what people like to use. Be prepared to shell out some cash for good stuff man
Old Feb 10, 2010 | 06:58 PM
STOCK_SOHC_DX's Avatar
This is one of the reasons why those brands shocks blow really fast.
I would contact Progress before buying any of those, I have read some where that their shocks can handle up to 1000lbs springs.
Old Feb 10, 2010 | 09:49 PM
eg515's Avatar
ok thanks im going to ask in the drag section
Old Feb 11, 2010 | 08:43 AM
AZDC's Avatar
According to Google, 1000 lb/in springs are approx. 17.9 kg/mm.
Also- In my opinion, I wouldn't feel comfortable running a shock with such a deviated spring rate. I would suggest getting something that's valved specifically for that rate.
Ksport has the RR's which are valved to your specs. Not sure if Progress has something similar.
Old Feb 11, 2010 | 01:32 PM
racebum's Avatar
blox has a similar shock with the exact rates you're after
http://cgi.ebay.com/ebaymotors/ws/eB...d=300282744669
no clue what the construction or valving is like but i doubt it's any worse than omni, form function etc...
Old Feb 11, 2010 | 02:57 PM
eg515's Avatar
thanks man ^^^^
Old Feb 11, 2010 | 03:03 PM
Egezzy's Avatar
Spongebrad Squarepants
yeah but like was said before. going to be dishing out decent money for them. like koni ssp3s are rated for 1000lbs but you are spending 1200 in just dampers. the route he is going i dont think he is looking to spend that.
Old Feb 11, 2010 | 03:04 PM
Egezzy's Avatar
lol.
Old Feb 12, 2010 | 03:34 AM
eg515's Avatar
is it true that omni discontinued there drag coilovers
Old Feb 12, 2010 | 07:10 PM
eg515's Avatar
found the info i was looking for thanks guys
racebucket_eg
Suspension & Brakes
Nov 9, 2007 09:02 PM
mofuckinarnell
Suspension & Brakes
Jun 30, 2005 12:41 PM
SNsLude
Dec 18, 2004 11:21 PM
USCdrifter
Apr 27, 2002 01:18 AM
The Punisher
Apr 19, 2002 07:12 PM
