EG to EF suspension
I put Koni SP3 yellows on my CRX that I took off my EG hatch. The rears are the same but the fronts you are going to have to use EG forks. The setup worked but did not allow enough up travel and constantly bottomed out on the bump stops. I had the car sitting at 12" from hub center to edge of fender. So not even that low. Took the Konis off and sold them and went to Progress CSII coilovers and it rides great. Still sitting at the same ride height. Hope this helps.
