NEED HELP AGAIN REALLY BAD
Old Feb 10, 2010 | 10:56 AM
M.D. CIVIC's Avatar
Default NEED HELP AGAIN REALLY BAD
ok i got everything hooked up on my d16y7 motor and its in the car i started it and it ran for like 20 seconds perfect but then it started making a whining noise and i dont know what it is. any ideas
Old Feb 10, 2010 | 10:57 AM
zerovandez's Avatar
Default Re: NEED HELP AGAIN REALLY BAD
Have enough transmission fluid?
Old Feb 10, 2010 | 10:59 AM
nothing_shocking's Avatar
What kind of whining noise? Is it constant? Did you put a new timing belt and tensioner on?
M.D. CIVIC's Avatar
its stick i had it in neutral and it didnt leak any when i pulled the tranny out
Old Feb 10, 2010 | 11:01 AM
M.D. CIVIC's Avatar
no i didnt touch the timing belt and or tensioner and its constant if you want to call me so you can hear it your more than welcome my number is 262 893 7103
M.D. CIVIC's Avatar
i was told maybe the water pump
Old Feb 10, 2010 | 11:02 AM
M.D. CIVIC's Avatar
it ran perfectly for like 20 to 30 seconds though when i pressed the gas a few times is when the whining started
Do you know how many miles are on it? It could be the tensioner going bad or possibly an over tightened power steering or alternator belt.
Old Feb 10, 2010 | 11:04 AM
M.D. CIVIC's Avatar
it has 145000 miles on it and i can check the alternator belt how do you know if its too tight oh and could it be the a/c belt to tight too
Old Feb 10, 2010 | 11:10 AM
Is it a motor you just bought or was it your original? As far as checking the belts, just push on them to see if there's any flex or if it's really stiff. It should flex a good bit when you push on it.
Old Feb 10, 2010 | 11:13 AM
TheAsian's Avatar
Try removing the alt and a/c belt. If the noise is still their you will have eliminated those things.
Get a stethoscope and take a listen to the timing cover see if you can pinpoint the area which is making noise
Old Feb 10, 2010 | 11:15 AM
Don't really need a stethoscope, just use a long, plastic handle screwdriver. Works just the same, just not as flexable.
Old Feb 10, 2010 | 11:18 AM
TheAsian's Avatar
Agreed but you can pick up a stethoscope for about 6 bucks at auto zone nappa and what not.
If you use a screw driver just make sure it is a hard plastic handle. Better ones some techs use have the metal run all the way to the base and they grind it down until the metal is showing.
Old Feb 10, 2010 | 11:25 AM
M.D. CIVIC's Avatar
ok so the belts are a little tight but i tried starting it again and let it ran for like 40 to 50 seconds and the whining faded a little bit i didnt touch them yet so would that forsure be the belts
Old Feb 10, 2010 | 11:31 AM
Just loosen them up. I'm not sure how to loosen the a/c belt since I've never had a/c, but the power steering belt is just 2 bolts on the mount and then the long, skinny bolt going into the pump and the alternator is one bolt on the slider looking thing.
Old Feb 10, 2010 | 11:39 AM
M.D. CIVIC's Avatar
yeah i dont have power steering
Old Feb 10, 2010 | 11:40 AM
M.D. CIVIC's Avatar
its shooting the po141 code for obd II whats that mean
Outlaw-Hondaz
Oct 9, 2009 05:31 PM
NikeSB
Sep 14, 2006 04:23 PM
.Noah Fecks
Feb 8, 2005 12:31 PM
GroundZer0
Jul 24, 2004 06:24 AM
ShaolinRider
Sep 24, 2003 09:27 AM
