port and polish
anyone know any information about how much i should port and polish the intake and the exhaust of a b16a head on a b20vtec?
11.0:1 cr
skunk2 pro1 cams
skunk2 pro manifold and 68 mm tb
tri-y big tube header 2,5"
should i port 0.040" or 0.080" from the intake side and what about the exhaust side?
should i port the intake manifold too?
11.0:1 cr
skunk2 pro1 cams
If it is really something you want to tackle yourself, just blend the seats, match the ports and smooth out any significant casting flaws. Doing any more than that to a Honda head is rolling the dice unless you know what you are doing. Its not like old V8 heads where you can work the short side radius, hog the ports out and nearly always see a performance increase.
SymphonyX
May 13, 2003 08:21 PM
