Oil pan gasket, hard as rock!
Old Feb 10, 2010 | 10:13 AM
TheOdd001's Avatar
Default Oil pan gasket, hard as rock!
I dropped the oil pan today to tap the oil pan for a turbo drain and the old gasket is ON the pan... It will not come off I've been chiseling away at it piece by piece... Does any one know of a good way of getting the old gasket off? I tried spraying it with brake cleaner and letting it sit but it hasn't done much good, can I use a torch and burn it off?
Old Feb 10, 2010 | 10:42 AM
mouab18c1's Avatar
Default Re: Oil pan gasket, hard as rock!
they sell gasket scrapers at napa and schucks
Old Feb 10, 2010 | 10:46 AM
pk386's Avatar
scrub scrub and scrub some more... oil pans suck unless you have a hot tank.
you could use a wire wheel but make sure that you spray paint the edges when you're done to keep it from rusting.
Old Feb 10, 2010 | 10:52 AM
rayzda's Avatar
if you can use a die grinder it works great
Old Feb 10, 2010 | 11:11 AM
.Manny.'s Avatar
Touching My Member
I'm guessing you can use a torch. try whatever the hell will take it off without damaging the pan. good luck
Old Feb 10, 2010 | 12:02 PM
SpeedFactoryRacing's Avatar
Make sure to check that the pan is flat around the sealing surface before you reinstall it. We have seen many oil pans warp and cause leaks.
Old Feb 10, 2010 | 12:26 PM
fcm's Avatar
fcm
Old Fart
Torching is probably not a good idea, you may warp the pan.
As mentioned, a gasket scraper is what you need... http://www.bettymills.com/shop/produ...899&OVNDID=ND1 a wire wheel for a drill will help get the last of it... http://www.makita.com/en-us/Assets/I...brushes/4L.jpg
Also as mentioned, repaint. 94
somick
Aug 3, 2017 08:45 AM
StreetRacinThug
Dec 21, 2006 08:44 AM
honda4674
Aug 22, 2006 09:56 AM
mstewar
Aug 1, 2005 10:50 PM
deconstruct
Jun 18, 2004 01:00 PM
