need help fast
Old Feb 10, 2010 | 04:48 AM
graffini's Avatar
Default need help fast
ii have a 95 accord and i just put new inner and outer tierods and upper control arm on one side of my car this weekend was plannaing on doing the other side next weekend, the new ones are on the drivers side and when i take a right turn i feel this wierd kinda like rubbing noise and sometimes its pretty bad it makes me nervous i did something wrong, It only really does it while taking a right turn or moving from the left lane to the right. I could really use some help before it causes damage
Old Feb 10, 2010 | 08:59 AM
hondamark35's Avatar
Default Re: need help fast
it's hard to guess at something like that without seeing it in person...
i would get under there and check everything over with a light, make sure everything is tight and you don't see abnormal wear from rubbing.
for your sake i hope you do find something and that it's an easy fix.
Old Feb 10, 2010 | 09:08 AM
02 accord's Avatar
Did you get it aligned? It could be your tires getting dragged across the road.
Old Feb 10, 2010 | 04:23 PM
davey5300's Avatar
you most likely installed a tie rod end for the right side onto the left side. The way it bends would make the wheel rub against the rod when you make a turn.
Old Feb 10, 2010 | 06:15 PM
bRamsey141's Avatar
im new to the threads so i cant post my own yet, so im gonna post one here just for a minute.. can a 245/45R17 tires fit on my 93 accord SE/??
Right now all it has on it is 195/60R15's and i got new 17'' rims so i need to know ASAP if they would have the proper clearence to fit and not rub or scrape pn anything.. any help would be great thanks..
slimtruepimp
18
Dec 6, 2012 09:04 AM
1badcrx
May 13, 2011 09:05 PM
1lowsol2
Dec 29, 2006 06:20 AM
Badger401
Aug 13, 2004 02:55 PM
Eresuncabron
10
Dec 12, 2003 01:45 PM
