91 accord h23 vs k20 vs k24
Old Feb 10, 2010 | 04:13 AM
f22a1 ftw's Avatar
Default 91 accord h23 vs k20 vs k24
okay well im going to swap my stock f22a1 for either a h23 vtec blue top or a k20/k24 can anyone tell me the pros and cons for each one i was leaning more towords the h23 blue top becuase with very little work it can be a 2.5l no problem so yea any help would umm help thanks
Old Feb 10, 2010 | 05:55 AM
GhostAccord's Avatar
Default Re: 91 accord h23 vs k20 vs k24
What is your budget and what are your plans for the motor?
When you talk about taking an H23 and making it a 2.5L. What do you consider very little work? A stroker kit and sleeves is about as much work as one can do to a block. $$$$
Old Feb 10, 2010 | 02:18 PM
f22a1 ftw's Avatar
i kinnda forget what i had todo but my buddy was saying is that a h23 dohc bluetop vtec is a 2.5l idk jus going off what he said but my budget is about 6,000 but atm im saving up for the swap and ima get tranny and a ecu with
6gs im gonna have to play with but i was jus asking which is better a k20/k24(ivtec) frank or a k24(ivtec) or a h23 vtec bt
also the purpose of the vechile is a fast dailydriver its also gonna be boosted and all that good **** in good time
Old Feb 10, 2010 | 02:24 PM
Atreidies's Avatar
What are your HP goals for that budget?
Old Feb 10, 2010 | 02:36 PM
f22a1 ftw's Avatar
tbh id be happy with 290-310 whp but the maiinn reason is my f22a1 is kinnda how do u say...umm...****?but my main goal isnt just flat out speed and raw power i like when a car can do well at the strip and the track and still beable to be driven daily and if this matters im putting a full skunk2 supesion on it lowerin it 1 inch and though some work equip 03s (15") wrapped in kuhmos..so yea i mean money really isnt a problem im jus asking which all around motor is better a k24 or a h23 vtec bluetop
Old Feb 10, 2010 | 02:44 PM
ok so save your money & rebuild the F22 for boost. You don't need DOHC VTEC or iVTEC for that. Plus the H23 is only 2.3L, not sure where your buddy is getting his info. Do some research into boosted F series engines. There are more than a couple making 300+ whp. without spending $600+ for a uesd block to start.
Old Feb 10, 2010 | 05:25 PM
Atreidies's Avatar
^x2. You could even get a f22 for a couple hundred, have it built, and get every part you need for boost so you can do it all in a weekend. All for less than $6,000.
Old Feb 10, 2010 | 05:45 PM
f22a1 ftw's Avatar
good point what u recommand the first things i should do with my f22a1 then?
Old Feb 10, 2010 | 06:05 PM
Tear it down and have it checked out. ie, have it cleaned up and inspected. Then check/replace the oil pump, water pump, tensioner and any other seals. Remove the balance shafts if you want. There is a cheap DIY on how to do a balance shaft delete on here somewhere.
Then go from the top down. turbo cam, springs if required???? Low compression pistons & rods. Then start putting together a turbo kit......That is something that someone else will have to fill you in on.....I'm not a boost guru. If I was to build one that is what I would do. Done right you will have a freshly built block for what you were goign to spend on a used engine and some parts.
Old Feb 10, 2010 | 07:00 PM
Atreidies's Avatar
I would say to go ahead and do valves, springs, and retainers. Might as well, and it won't throw you over budget. Turbo parts needed are Turbo, blow-off valve, wastegate, intercooler and piping, turbo manifold, oil lines, bigger injectors(550cc or higher), upgraded fuel pump, new exhaust system(at least 2.5", preferably 3"), boost gauge, oil pressure gauge, fuel pressure gauge(optional, but recommended), and get your ecu dyno tuned.
You can also get a turbo timer. It can help to extend the life of your turbo.
You will also need a clutch/pressure plate combo to handle the power. If you want to get a lightened flywheel, get a chromoly one that is no less than 11 lbs.
And DO NOT, I repeat DO NOT buy a ebay turbo kit. The seals on the turbo start to leak around 10 lbs. You can however save a bit by buying the intercooler, BOV, and wastegate from there.
Old Feb 10, 2010 | 07:14 PM
ilikehonda's Avatar
www.f22parts.com will be your friend. the ya a crap ton of parts for you motor all in one place.
Old Feb 10, 2010 | 07:16 PM
TheMuffinMan's Avatar
He knows where you live!
Why don't you just do an LS1 swap
Old Feb 10, 2010 | 07:25 PM
tamadrummer1120's Avatar
The swap threads are always humorous.
just friggin boost it. or actually spend close to 10k on everything for a k, just to say hey, i dont have that much more power than i started with but i am so cool cause i have a k.
boost it. over twice the horsepower with a little over a grand. yeah. im sold.
Old Feb 10, 2010 | 07:52 PM
davey5300's Avatar
drop an H22or F20B and stay NA...turbo is cheating and cheaters never win
Old Feb 10, 2010 | 08:38 PM
Happy Gilmore's Avatar
Get yourself an EX trim ECU
H23 IM and TB
F22A6 Cam
As stated above tear the engine down and check internals and then of course rebuild for boost!!!
Boosted F! FTW!!!
Just my 2 cents
Old Feb 11, 2010 | 01:11 AM
SuShiBoiiii's Avatar
f23!
Old Feb 11, 2010 | 07:09 AM
f22a1 ftw's Avatar
im sorry im mostly jus a honda guy and roam into any thing other then hondas but i dont think i know what a ls1 even is
Old Feb 11, 2010 | 08:18 AM
lol ..... an LS1 is a 346 in³ (5.7L) GM performance V8.
Old Feb 11, 2010 | 10:46 AM
crx_91si's Avatar
F23 FTW! lol
Air cooled crank hole!
Old Feb 11, 2010 | 11:02 AM
What was the state of that engine and what were the conditions that it was enduring to cause this catastrophic failure?
Old Feb 11, 2010 | 11:14 AM
crx_91si's Avatar
68k miles when it blew up. Had a slight rod knock when i bought it. Over the next 3 years, it progressively got worse until i said **** it, stopped changing the oil, and beat the living **** out of it for 2 months. Then, kaboom!
This is one of the strongest built SOHC engines.
BTW, It still ran with that huge *** hole in the block believe it or not. It didn't run good, but it ran.
I caused the failure, but i can say that it was one strong engine.
Old Feb 11, 2010 | 11:22 AM
Ok now I see - the picture painted a totally different story to me. I thought you were saying that the F23 were junk.... Misinterpretation!
skatebrooklyn89
Sep 17, 2010 06:42 AM
01Accordf23
Jul 22, 2009 05:57 PM
7808
Oct 6, 2003 09:19 PM
