Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission issues
Old Feb 9, 2010 | 05:04 PM
andrewd_89's Avatar
Default Transmission issues
Ok quick question...what is the most probably cause of: clutch pedal vibration+transmission pissing oil+whining noise when accelerating. Intermediate shaft bearing or main shaft bearing? If not those then what else?
Old Feb 10, 2010 | 08:52 AM
Nealoc187's Avatar
From: West suburbs of Chicago, IL formerly Kalamazoo, MI
Default Re: Transmission issues
Input shaft bearing is my bet. Clutch disk rides on input shaft splines and input shaft goes through the case of course, and has a seal around it. Once that bearing gets bad enough, play causes the seal to fail at sealing resulting in trans oil coming out.
Old Feb 10, 2010 | 04:21 PM
andrewd_89's Avatar
thats what i was thinking, because it didnt start leaking until a couple days after the vibrations started
Agent Daimon
Apr 3, 2008 05:04 PM
crxnj
11
Oct 9, 2005 06:42 AM
BI8B
Sep 16, 2003 06:14 AM
keithv
21
Mar 11, 2003 04:11 PM
