this car is trippin!!
Old Feb 9, 2010 | 11:43 AM
94accord25's Avatar
Default this car is trippin!!
94 accord non vtech... it was actin like the ignition switch was gone. it would only stay running with the key held in the start position however when i took the column apart to check it i kinda jiggled it around and it started and ran fine!? its the worst when its cold. whats goin on?
Old Feb 9, 2010 | 12:19 PM
soLaLive's Avatar
Default Re: this car is trippin!!
ey man..my sol is doing the same thing too..sht...
i was driving and all of a sudden it stopped...
but i looked at it and call a buddy and he said that its might be the white piece from the key ingition..sht...
Old Feb 9, 2010 | 01:15 PM
94accord25's Avatar
yep mine did stop all of a sudden as well but its not very often. for the most part it starts and runs well. its jus every now and then it will start and then die when its cold and i can move the wheel around and jiggle the key and it will start normal and continue until i let it sit
Old Feb 9, 2010 | 01:17 PM
94accord25's Avatar
my uncle is a honda specialist who owns his own shop. its just hard to get him to help out cause he is always busy. if i can get with him on this i will post the answer.
Old Feb 10, 2010 | 10:24 AM
curiousdude's Avatar
theres some loose **** in the ignition.... you car been stolen before?? they probably master keyed your ignition and fked it up. i say, jus replace the ignition lock.
1yesfan
Apr 6, 2016 03:50 PM
Noob@Cars
Jan 11, 2012 10:39 PM
prelude504
Sep 7, 2009 03:19 PM
crazedx
Sep 24, 2007 11:29 AM
