Water hose extending for MPFI swap.
Old Feb 9, 2010 | 10:25 AM
Fo-Do Fanatic's Avatar
Default Water hose extending for MPFI swap.
I called up SpeedFactory today and they said they wanted like $480 to do the MPFI swap JUST for labor, NOT including the wiring. I figured I'd go ahead and tackle it myself but they said something about some coolant hoses needing to be extended? Which ones, if any, need to be extended? Can i use all the stock hoses off my DPFI mani for the swap?
TIA
Old Feb 9, 2010 | 10:52 AM
beansandrice's Avatar
Default Re: Water hose extending for MPFI swap.
480?? Is that with or without vaseline!
That is expensive for 1 hours worth of Wiring work. Unless that includes the swap then water line changing makes sense.
Old Feb 9, 2010 | 11:16 AM
4drEF's Avatar
Keyboard Humorist
480 for LABOR ONLY?
I'd really like to see how they justify that especially since no parts nor wiring labor is included.
For what they are doing it's literally less than 15 nuts and bolts that you have to wrench on. You are simply changing out the intake manifold.
No coolant lines are extended that I can think of.
Old Feb 9, 2010 | 11:18 AM
Call the cops and press "attempted rape" charges on them.
Old Feb 9, 2010 | 12:02 PM
lif3tak3n's Avatar
:rotfl:
Old Feb 9, 2010 | 01:44 PM
BiG ChOr!Zo's Avatar
i dont think it includes the vaseline since that would fall under extra materials and not labor
Old Feb 9, 2010 | 02:49 PM
Ya they said it would take about 4-5 hours to do it all. And 3 of the hours was changing out the intake manifold....I just do not trust myself to do the wiring. I have everything I need but the TD-02 dizzy plug. But I dont think you "need" it.
Edit: I just called them just to verify the price and they said and I quote "So you want us to put on the intake mani, injectors, fuel rail, distributor, and do all the wiring...about 5-600 dollars" what the flying frucking jesus.....
Old Feb 9, 2010 | 02:54 PM
garageEF's Avatar
There is a coolant hose on the intake manifold near the thermostat housing that needs to be changed out. It is "U" shaped on the MPFI manifold and im not sure how different the DPFI hose is but it isnt the same.
Old Feb 9, 2010 | 02:56 PM
sounds like to need to find another shop,hater-tech member or follow a DIY...!!!
Old Feb 9, 2010 | 02:57 PM
I think you should just read up on the install and wiring schematics and just do it yourself save up 500-600$$
Old Feb 9, 2010 | 02:58 PM
heck spend the saved loot on new Suspenions bushings, rebuild your rides ride.
Old Feb 9, 2010 | 03:07 PM
Lets not even get me on the topic of my cars suspension. Talk about a damn nightmare..
And I've been reading the DIY's on it and the wiring seems so easy but me and electrical stuff don't go hand in hand.
ANYONE IN THE PACIFIC NORTHWEST WANNA HELP!?!? LOL
Old Feb 9, 2010 | 03:12 PM
http://www.haimports.webs.com/
Old Feb 9, 2010 | 04:05 PM
garageEF's Avatar
I will.
Where you at in washington?
Old Feb 9, 2010 | 04:19 PM
Phoenix007EF's Avatar
hell, i need help with mine. Im in Columbia, S.C. and will provide all the parts, a 6 Pack and $50. I have a 91 std. with a punk *** d15 and i think that going to MPFI now is gonna greatly help me-and it needs to be done anyway because i plan on doing a swap in the next 6 months. So... What up any S.C. Guys Wanna Help a Noob !! Ill make sure i get everything I need before hand !
Old Feb 9, 2010 | 08:37 PM
uberEFtuner's Avatar
When I did my mpfi swap I bought a hose stretcher. Nah I just asked to look at all the hoses at the auto parts store. I found a nice long U shaped hose that worked fine. The hose goes from the cylinder head to the thermostat housing.
ascarberry
Apr 12, 2011 06:23 AM
blinger
Jan 26, 2007 01:02 PM
Imsleeping
Jun 9, 2005 01:52 PM
Rival23
Oct 25, 2003 09:34 AM
