Cant get axle in.
Old Sep 6, 2002 | 12:10 AM
shortyz's Avatar
Default Cant get axle in.
i cant get the axle in all the way. i have splined the axle in and it has to go about another 2 inches. the short axle went in alright. but this ones being a real bugger!!!
i changed the snap ring with the old one. but is there something i have to do to get this dam thing in right!! help
also how do people get that dam crank pulley bolt off. it wont budge!
Old Sep 6, 2002 | 01:35 AM
88civic's Avatar
Default Re: Cant get axle in. (shortyz)
the axle just needs a good push with 2x4 and a sledge hammer put the wood on the axle close to the trans. and wack away till it sets it self but make shure the teeth are in right. I had the same problem with the same axle..
the crank pully bolt is the hardest bolt to get off what i did is got some white lithium grease and soaked it over night and then got a couple of 1/2in extensions with an empact socket and a huge bar or tubing for leverage and placed a chunk of wood under the rachet.. it will come off with force. (alot of force)
good luck!
Old Sep 6, 2002 | 05:32 AM
keithv's Avatar
pull the snap ring first and make sure the axle fits all the way into the tranny. once you see that it does that, put the snap ring back on and get a friend to help. in one movement, both push the axle into the tranny. that is what worked for me.
although i have used a dead blow hammer on an axle before. remember to compress both joints before you do this!
Old Sep 6, 2002 | 09:00 AM
shortyz's Avatar
Default Re: Cant get axle in. (breaka_1_9)
ok cool.
i might just drive it down to a shop to get that crank pulley bolt off..
that thing aint moving. im afraid imma break it.. will iit break?
Old Sep 6, 2002 | 09:01 AM
shortyz's Avatar
88 civic wont that 2x4 pinch the boot and tear it?
Old Sep 6, 2002 | 01:00 PM
mr. carpenter's Avatar
we tapped it in with a rubber mallet
Old Sep 6, 2002 | 01:57 PM
REDBARON's Avatar
Default Re: Cant get axle in. (mr. carpenter)
When I put mine in, I leaned over and my support hand slipped from underneath me and I pushed it into the tranny by accident....?? It just clicked right in.
Old Sep 6, 2002 | 05:19 PM
shortyz's Avatar
Default Re: Cant get axle in. (REDBARON)
thanks to 88 civic i ripped the boot with that 2x4. i suggest not using 2x4's against the boot. ends up i had a spare boot off the old ones and i went to honda and got them ti change the spline and boot. only 50$!
lol
but after the spline change it went in fine.
thanks.
Old Sep 6, 2002 | 06:18 PM
shortyz's Avatar
GOD DAM DRAIN PLUG FOR THE TRANI WONT MOVE!!!!!!!!!!!!!!!! WTF
im pissed off so much
im afraid i will rip a chunk outta the trani if i give it some serious power
who decided to put the drain plug there?
i mean wtf
cant even get a socket on it!!!!!!!!!!
Old Sep 6, 2002 | 06:22 PM
FUP23's Avatar
New User
are you using the 17mm bolt or 1/2in drive hole ?
Old Sep 6, 2002 | 07:53 PM
shortyz's Avatar
Default Re: Cant get axle in. (Devin17)
haha i got the bugger off.
uhm engine code is throwing a 10
blinks 10 times... whasts up
Old Sep 6, 2002 | 07:59 PM
shortyz's Avatar
intake air tempature - Check intake air temperature (TA) sensor and replace if necessary.
Old Sep 7, 2002 | 12:35 AM
shortyz's Avatar
where is the air tempature TA sensor?
help
Old Sep 7, 2002 | 08:33 AM
89 CRX SI's Avatar
donno but i live close to langly. i live in kelowna BC about 2 hrs away. It is nice too see more BC ppl on ths board now.
Well for the crank pulley bolt drive around to several shops and get them to use ther tourque gun on it and once you find a shop with a big gun itll come off then tell them to put on lightly.
soak over night with what ever yo want liquid wrench pr somthing.
Most shops wont have a big gun so dont expect it to come off right away. thell all do for free too.
wasanissanFL
Honda Fit
Mar 8, 2012 06:51 PM
dynamo
13
Nov 14, 2005 08:22 PM
EFM_ookie
16
Aug 14, 2005 09:27 PM
david90
Mar 31, 2004 11:41 PM
Feb 19, 2004 08:54 PM
