oil in the radiator and over flow
Old Feb 9, 2010 | 07:04 AM
silent702's Avatar
Icon6 oil in the radiator and over flow
i got a another 98 accord had the gasket change from this shop but there oil keep comin in the radiator and over flow well of course if its in a radiator its gonna go to the over flow too cant figured it out ! had the gasket change too is there oil in the radiator tht just keep comin out or is it comin from the head ?
Old Feb 9, 2010 | 07:10 AM
tamadrummer1120's Avatar
Default Re: oil in the radiator and over flow
what gasket did they change?
if they did the head gasket then take it back and tell them its wrong. you have oil getting into the coolant passages. which means you also are probably burning coolant too. They may have not of sent the head away to get it machined, or just didnt torque it right.
Now one other thing before you jump to that, how old is that coolant? Sometimes really old coolant will get a rusty look to some of it.
Old Feb 9, 2010 | 07:34 AM
GhostAccord's Avatar
Could be a few things,
1. They didn't flush the old oil out of the cooling system after the head gasket job.
2. They didn't have the head warp tested or resurfaced and it is leaking again. or
3. There might be a crack in an oil passage somewhere inside the block.
Old Feb 9, 2010 | 07:47 AM
silent702's Avatar
hmm well the thing is the car is friend of mines and he paid too much money for the head gasket he went to this sonic auto repair idk sum bs the mechanic tellin him now tht he should change the whole motor but i told him hes just tryin to get more money out of him anyways he paid like 800 bucks i did mine by myself . and he took it back like 3 times everytime i think they flush it and it comes right back n now finally he brought the car to me so i can take a look at it but i cant figure it out because the car runs perfect its got compression the head looks super clean theres no oil on it looks like they watter pressured it or sumthin but its clean...
Old Feb 9, 2010 | 08:22 AM
Do a pressure test on the cooling system and that should show you where the oil is coming from. By adding pressure to the cooling system without oil pressure in the block you will be able to reverse the flow and see where it is leaking.
Azimmer
24
May 9, 2012 02:34 PM
killa4lyfe
Jul 12, 2009 08:06 AM
apeek
Jan 23, 2008 07:28 PM
ujhonda
May 11, 2006 04:29 PM
JDM_ITR
Jun 28, 2002 12:47 PM
