help me wire my head unit.
Old Feb 8, 2010 | 05:12 PM
pedroa06's Avatar
Default help me wire my head unit.
well they stole the stereo and cut the wires leaving me with not even the oem adapter on my 4 door ef..
i used this which is very accurate by the looks of it
http://www.installdr.com/Harnesses/HA-Wiring.pdf
but i seemed to wired everything correct and even switched out fuses but it wont turn on any help?? lolz
no adapter used..
Old Feb 8, 2010 | 10:00 PM
bmxkills's Avatar
Default Re: help me wire my head unit.
Make sure the 12+ connections are right, all connections are secure, and the ground is right... Also check the dimmer. Usually it's something stupid like the head unit turns on weird, or a lot of the wires look similar, and one is crossed.
Old Feb 9, 2010 | 11:42 PM
dcteg513's Avatar
you can use a multi meter to find your constant 12v,your acc 12v'ts also....anyway the constant keep key out of car touch wires until you see 12v ,next acc12v keep car off touch each wire to meter you should get 0v then turn key to acc postion until you find one that switches to 12v.. do one wire at a time for this in the shop we charge $35 to do this.. be patient and you will fix it
DJNauTicz
13
Apr 7, 2007 10:11 PM
92_honda_hatch
Sep 28, 2006 09:06 PM
95civickid
Audio / Security / Video
Mar 25, 2005 07:54 AM
Trackman
Jul 5, 2003 11:29 PM
rota426
Jun 18, 2002 04:17 PM
