f2b vs h2b install
Old Feb 8, 2010 | 04:59 PM
speedfreak44's Avatar
Default f2b vs h2b install
ok just came from my local jdm parts garages and saw f20b sir and h22a , now the project is the h/f2b swap on a eg civic, now from the looks of it, the h22 crank is wider due to two pulley groves and the f20 has only one due to no p/s pump,
so the theory is with the f2b swap i wont have to bang the sub frame
as wit the h22 i would to accomdate the extra width,
no i have my eyes more on the f20, so if i was to line up a h22 or b series p/s pump with a longer belt, meaning still using one belt for all, allt, ac, ps, this would b nice,
anyone have person experience with this,
the main thing is i hate the fact of banging my sub frame, i just hate it, so if there is anyway it can be done with out this i will consider it,
if not i will just go with the f20b and box and product change the ratios, what you think?
Old Feb 9, 2010 | 02:16 AM
Default Re: f2b vs h2b install
anyone with experience
Old Feb 9, 2010 | 04:19 AM
Kyle R's Avatar
You won't have to hammer the frame rail if you shave the crank pulley (h22), remove the balance shaft gears, and move the crank pulley/alternator 1/2" in.
Old Feb 9, 2010 | 04:53 AM
jdmwannabee's Avatar
not a chance.
for the ac and ps you'll need custom lines/ belts. unless you can braze it's going to be kind of expensive. most people usually just get rid of them anyways.
good luck
Old Feb 9, 2010 | 10:44 AM
ok thanks is it the same for f20b?
steven32782
Sep 22, 2008 08:14 AM
blueBB4lude
May 1, 2006 11:30 PM
nikolai.
15
Apr 6, 2006 07:05 PM
