Suspension & Brakes Theory, alignment, spring rates....
H&R SPORT SPRINGS w/ KONI SPORTS
Old Feb 8, 2010 | 12:46 AM
jonnybadboi9's Avatar
Default H&R SPORT SPRINGS w/ KONI SPORTS
before I buy, i had some questions reguarding the setup... I have looked online everywhere and read sooo much about this already but wanted some more opinions from those who HAVE/HAD experience with this setup...
I was looking to get some Koni Sports(yellows) and H&R springs, but not sure which spring.
I am most likely going to get the H&R Sport springs because i want a good drop but not too much to where id be bottoming out like ive heard with the H&R Race springs. (is this true?)
What I want to know is will the H&R sport springs lower a little bit more than theyre suppose to with KONI SPORTS??
I have heard they would give a slightly lower drop than the specs say...
*post pics of ur rides on sports or race springs with koni yellows plzz*
Old Feb 8, 2010 | 07:37 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: H&R SPORT SPRINGS w/ KONI SPORTS
Had them, they sucked. Springs were way too soft for the amount they dropped.
Old Feb 8, 2010 | 12:57 PM
which setup did you have? koni with h&r sport or race?
Any suggestions??
Old Feb 8, 2010 | 02:05 PM
Community Builder
Had the setup you listed in your thread title.
Old Feb 8, 2010 | 08:58 PM
lyncoors's Avatar
i have the said springs on 195/50 tires and i really dont want to be that low
Old Feb 9, 2010 | 07:10 AM
bsmith100's Avatar
I am fairly sure the H&R Race springs are linear rate, so I wouldn't go that route. It will feel like you are driving around on coil-overs. I haven't used the H&R sport springs so I can't comment on the rate.
You could always go with Eibach Sportlines which will drop the car about as much as H&R Sports, or with Eibach Pro-kits which will leave the car a little bit higher. In my opinion the spring rates of the Eibach springs are appropriate for the drop.
Old Feb 9, 2010 | 08:25 PM
kommon_sense's Avatar
Had the h&r sports w/koni yellows for several years on a 98ex. Loved the setup. The car was a daily driver and I did several hpde events a year. The h&R sports is about as stiff as you want to go on a daily driven setup.
They did initially drop the car a big lower than I wanted, but I simply used the adjustment rings on the koni sports to raise the spring perch up about 1/4".
Here are some old pics of my car :
This pic is a left hand turn, so you can see the suspension somewhat loaded :
ONe21
Suspension & Brakes
33
Jan 26, 2017 03:41 PM
jonnybadboi9
Sep 16, 2010 02:56 AM
guero2craze
Jan 13, 2007 10:12 PM
ChaseIntegra
Dec 7, 2001 01:27 PM
comptechgsr
Nov 26, 2001 06:57 AM
