Suspension & Brakes Theory, alignment, spring rates....
EG Rear LCA Strut bolt head broke
Old Feb 7, 2010 | 02:13 PM
dapek's Avatar
Default EG Rear LCA Strut bolt head broke
As title says, the classic breaking rear lca bolt happened to me not too long ago. I just had a question on how to break the welds on the welded on nut (the one that's welded to the strut). How you you break that exactly? Is it just tack welded on?
Thanks.
Old Feb 7, 2010 | 07:16 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: EG Rear LCA Strut bolt head broke
arent you the one with the bc coilovers?? if so why does this action need to be done?? use new stuff.
Old Feb 7, 2010 | 07:23 PM
dapek's Avatar
Yes I am, and I purchased all the new rear bolts from Honda for it. I am replacing them with new parts (as I said in my build thread) but in order to replace it with "new stuff" I need to remove the existing suspension/bolts that are on there.
It would be nice if I could just use new stuff without figuring out how to remove them, but i'm stuck with seized bolts on the control arms if that makes sense. I have an ASR rear sway bar already that I had on an older car, but I planned on purchasing new control arms and a subframe brace seeing as how all the bolts seem to be seized anyways.
What would be the best way to remove the control arms then?
Old Feb 7, 2010 | 11:30 PM
STOCK_SOHC_DX's Avatar
When my bolts snapped I ended up chucking the LCA's and struts all together and going with Function7's. But yes those nuts are just tacked on you can breaker bar them right off.
Old Feb 8, 2010 | 06:30 AM
Egezzy's Avatar
yeah sorry i was assuming that you had new lcas. like stock dx i always use new lcas. rather spend a few extra bucks to not have to deal with that headache.
Old Feb 8, 2010 | 06:56 AM
dpetro1's Avatar
take the entire lca off and then cut off the strut with a sawz-all. cutting between the strut and the bushing is your best bet. once the strut is cut off, get the bushing pressed out and replace with a new one. or repalce the lca's if you want the easier but more expensive option
Old Feb 8, 2010 | 10:39 AM
dapek's Avatar
^^thanks guys I'm just buying new lca's it's still gonna be a pain to remove the others though.
Old Feb 8, 2010 | 10:57 AM
dpetro1's Avatar
the other 2 lca bolts came right now with no breakage for me on 2 different cars. for whatever reason those shock bolts get rusted on though.
Old Feb 8, 2010 | 06:56 PM
90blackcrx's Avatar
We have the PIC ones in stock an on sale. FYI
93b20z
Mar 21, 2011 09:12 AM
LavishTheKid
Jan 11, 2011 02:47 PM
b_serious
Oct 22, 2005 11:27 PM
thaimonkey
15
Jul 7, 2005 10:42 AM
95greenteg
Sep 12, 2004 06:13 PM
