93 turbo si hatch lsd f/t
ok so i want a 96 to 2000 ek 4 door. preferably with a b swap, lowered on decent suspension and a good body.
my car.
93 si hatch. stock d16z6 with a stock jdm lsd tranny. chipped ecu running crome.
i put the turbo kit together myself. its go a nice handmade stainless mini ram to a ching chiong 50 trim turbo.a 63 exhaust and spools really fast on this setup. turbonetics evolution wastegate. 2in pipeing hot side and 2.25 cold side.
hasport track mounts/black inserts. comp clutch flywheel and pressure plate and new not even installed act street disc. rx7 450cc injectors. clean resistor box install. 2.5 exhaust that needs to be finnished. it goes just past the rear seats now. running 6 lbs now. still need to put hte arp headstuds in feel safer past 8 or so lbs.
i forget the brand of shock and springs but the shocks are 5 way adjustable and it has a camber kit as well.
interior is clean but could stand to be cleaned. speedo acts up.
the shell needs a paint job witch it will get if someone wants the car and has a car to trade. i have doors to put on it. and a carbon hood. so that will be good to go and yo get to pick the color.
hatch needs new shocks or just the bolts htats ur call.
like i stated before. i want a 4 door ek with a b swap and mods
rims stay with me.
this was put together quikly so any ?'s just give me a shout. located in albany ga
my car.
rims stay with me.
88rex_zc
Oct 15, 2008 06:39 PM
soulrider4ever
Mar 8, 2006 09:30 AM
