d15b2 rev limiter?
Old Feb 6, 2010 | 03:56 PM
kyle48_2007's Avatar
Default d15b2 rev limiter?
alright i was thinkin about doin an mpfi swap on my car, but holding off for a little bit, cause i got a tach for my car and found out that my car has a rev limiter , lol, but the stock redline for the d15b2 is 6500rpm and the rev limiter should kick in at 6800 rpm, but my rev limiter kicks in at 4700 rpm...? is there a way i can chip the ecu to increase the amount of rpm's or what? i need help thanks
Old Feb 6, 2010 | 04:05 PM
JDhondaRI's Avatar
Default Re: d15b2 rev limiter?
Is the car an auto or manual ?
The ecu shouldnt have to be chipped to rev higher than 4700 because no d series i know cut out that low.
One possibility is that you have an auto ecu in a 5 spd which would be like revving an auto where it cuts out earlier unless you are in a drive gear. i could be wrong
Old Feb 6, 2010 | 04:06 PM
nope, 5 speed
Old Feb 6, 2010 | 04:15 PM
JDhondaRI's Avatar
The ecu is for a 5 spd ?
Old Feb 6, 2010 | 07:02 PM
no the car is a 5 speed, and i havent checked the ecu yet, but am going to right now
Old Feb 6, 2010 | 07:46 PM
~sp33~'s Avatar
EFB055
Does it sound like 4700rpm? Your tacho could be ****.
Old Feb 6, 2010 | 10:31 PM
.Manny.'s Avatar
Touching My Member
Might be a the tach. Please dont try to increase the redline past the stock 6500. there is no point
jetlude
Apr 19, 2011 03:39 PM
tenchi r
Mar 6, 2010 10:45 AM
KpaTyH
10
Feb 28, 2010 01:52 PM
thewrai6th
Aug 14, 2007 05:44 PM
exhaust
Nov 17, 2001 04:40 PM
