Will b20vtec arp headstuds fit my (Gsr) motor?
Old Feb 6, 2010 | 02:13 PM
1sicef9's Avatar
Default Will b20vtec arp headstuds fit my (Gsr) motor?
i just picked up a set of arp headstuds for my gsr motor ,i get home and i check the serial number (208-4306) and there not for a gsr, it comes up as headstuds for a b20 block with b16 head ....... so can they fit or should i take them back?
please tell me now before i open them and install them
Old Feb 6, 2010 | 02:21 PM
boostedteg1203's Avatar
Default Re: Will b20vtec arp headstuds fit my (Gsr) motor?
They wont fit. The end that threads into the block is thicker on the LS/B20. The ones you have should be thick on one end and tapper right past the threads and become smaller. You should need ones without a tappered end.
Old Feb 6, 2010 | 02:29 PM
1sicef9's Avatar
man,now i gotta wait to return them !!!why must people lie for?smh
Old Feb 6, 2010 | 03:09 PM
1sicef9's Avatar
somebody else sent me a pm that says they will fit....im confused
Old Feb 6, 2010 | 07:50 PM
1sicef9's Avatar
im going to call the shop i got them from first thing monday and see what there trying to pull
Old Feb 6, 2010 | 10:58 PM
If you take your stock head bolts out you should see that the tappered end on the arps is thicker than the bolt.
Old Feb 8, 2010 | 05:15 PM
ltrkstr2k's Avatar
Search seriously. Gsr headstuds = Lsv/B20v headstuds. the thickness has nothing to do with it its the length.
Old Feb 9, 2010 | 07:53 PM
SG_EM1's Avatar
New User
Im pretty sure they are the same but u should take the safe way and double check
hondastar361
May 11, 2016 04:31 AM
DAchiko
Feb 17, 2009 04:44 PM
DAchiko
Feb 17, 2009 02:01 PM
